You didn't cut down the tabs of your condenser at all to lower it too? What degree bend pipe did you use?
its a 45 degree intake i got from treadstone. i should have cut the tabs but i didnt think about it. waiting to see if zesus can post some pics of his so i can do the same thing.
it looks higher than it really is. the hood closes fine. haven't tested on the gains but i will be running next saturday. when i ran my 9.52 it was at 500 da, i will racing at 6000 da so it wont be apples to apples.
i acually cut my tabs down a little father then whats in the pics. man i wish i coulda found a chrome 4'' intake, then i wouldnt have painted evertthing black. yours looks really good
Also after looking at your pic again. maybe you could cut an inch off the pipe "filter side". That would lower the pipe down abit. just a suggestion to look into
Mine just hangs. I refuse to cut anything. I paid enough for the radiator I shouldn't have to cut anything.
I completely agree. All Dewitt's would have to do is move the tabs down an inch or two and it would fit perfectly. What's the point of a lowered radiator if the damn condenser is in the way. Btw I still love my Dewitt's rad lol
There is no need to cut anything on the radiator. All that needs to be cut is a little bit off the condenser tabs NOT the radiator ones. It took me 10 minutes with a Dremel cut off wheel. I agree tho DeWitt should change their tab locations cause they arent correct at all where they are. Kinda useless to buy a 4" cut down radiator and have condenser still sticking way high and having to mod further to utilize the drop down.
