turbo kits
Old May 15, 2012 | 04:02 PM
boostedcatfish's Avatar
boostedcatfish
Default turbo kits
ok im a big boost fan. i had a big turbo camaro ss, and i loved the way it ran. if i had to i could drive it daily and take it to the track and beat *** with it. the motor from that camaro is still good, so im planing on putting it in my new project. im unsure of how i want the setup to be like. my camaro was a single turbo and it would spool as fast as i needed it.
now ive looked at a few kits, sts, aps,tti, hinson. if im missing a company plz lmk. im not a fan of the sts's, idk but something about that much pipeing and oil lines makes me on the edge.
The tti's and aps's kits looks good untill i get to the cold pipes i dont like how they come through the innerfenders/wheel well area.
The hinson kit has really cought my eye. it is a front mount which i like, but the heat worries me. and im not sure how i like the water to air intercooler tho.
my question is what kits have you guys used, and whats the like and unlikes about them
Old May 15, 2012 | 04:16 PM
mdaniel's Avatar
mdaniel
Banned Scam/Spammer
Originally Posted by boostedcatfish
What kits have you guys used, and what's your likes and dislikes about them?
I've been running a TTi Stage X kit for the last six or seven years. This is a stock cube (346ci) setup and runs high 9s at 140+ even in the summer heat using pump 93 fuel.
Likes - Reliability (no belt issues), performance, sound (turbos just sound badarse), and adjustability (I can turn the boost up/down at the flick of a switch).
Cons - Hrm, I don't have any real bitches with the kit. I've heard installation is a bit involved, but I didn't care as I had a pro install mine. Some people in hot climates (FL) have reported heat issues where they ended up adding additional fans, hood changes, and so on. I live in the Mid West and haven't experienced such issues.
Old May 15, 2012 | 05:23 PM
regblkss's Avatar
regblkss
I have the hinson kit on my c5. I put a blanket on the Turbo. And I just put a a&a intercooler on in place of the air to water. Its a really ez kit to install.
Old May 16, 2012 | 03:48 AM
junk c5's Avatar
junk c5
I plan on copying the kit from unleashed performances single c5 build. I think their rwhp #'s are a little off, but i like how the kits placed. Im gathering parts now for the build. Car already makes 420 at the tire so I'll have a little more fun with that
Old May 16, 2012 | 06:32 AM
99FRC Newb's Avatar
99FRC Newb
i have a PTK style kit. its beautiful, but its a PITA to put on
Old May 16, 2012 | 07:52 AM
boostedcatfish
How does it drive on the daily? And how does the boost come in? What size turbo u running?
Old May 16, 2012 | 07:59 AM
boostedcatfish
Wow i just looked at the PTK ive never seen that set up. How bads the heat with that setup?
Old May 16, 2012 | 08:51 AM
99FRC Newb's Avatar
99FRC Newb
i've heard of heat issues, but i shouldn't have any. i have a tigershark front bumper (increased airflow), an ACP Stinger hood (increased airflow/designed for PTK kit) and a Ron Davis Radiator. i highly doubt i'll have heat issues
Old May 16, 2012 | 08:53 AM
nullpointer's Avatar
nullpointer
Pics? Results?
Old May 16, 2012 | 03:23 PM
venomws7's Avatar
venomws7
I made my own single turbo kit made 670rwhp 625rwtq with only 11psi and 13 deg of timing 10.9 A/F on 91octane Setup will easily make 800+rwhp with more boost.
Now I'm thinking about going 427ci LSX GT91 for 1300+rwhp
Old May 16, 2012 | 03:35 PM
boostedcatfish
how much do u drive that setup? do u have any over heating issues with that smaller radiator?
Old May 16, 2012 | 10:26 PM
speedmon's Avatar
speedmon
Most turbo kits are 80% plumbing....and the best way to do that is onsite fabrication. Then it just components..turbo, BOV, and WG
UV has a really good concept which is supported by the advance in turbo technology.....quick spool! and oil-less.
http://www.unleashed-performance.com...bo-c5-project/
I love the "catback" or mid/rear mount designs....easier fab, easier to install, maintain, etc. It separates the heat sources too....engine, trans, and turbo......Most "good" muffler shops can fab a mid/rear mount design.
A lot of japanese guys in my area (SoCal) have moved to this design(rear mount) as well. Its more of a "bolt on" design that can be removed quickly for smog(which is important for me)........or thrown on to another car. The all swear by that oil-less Comp CT43.....
Another thing they are doing is eliminating the intercooler. Because the air from the turbo gets cooled while its traveling from the rear. I did see one with an inline intercooler, looked like a 4 foot long cat with ram air fins on the bottom......but they said it didn't really help as much as they thought it would.
Old May 16, 2012 | 11:08 PM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
Lpe!
Old May 17, 2012 | 12:13 AM
regblkss's Avatar
regblkss
Well purchased the car with 408 with ls3 heads and epp blower cam t76 turbonetics Turbo. It will be dyno tuned
next month at new era
performance. Hope to make 700ish. Just finishing some changes I wanted to make.
Old May 17, 2012 | 12:37 AM
undertaker's Avatar
undertaker
From: ECS : WTF did you break now and HTF did you break it this time
Originally Posted by meadowz06
Lpe!
LPE would charge more than the C5 was bought for
To turbo kits
