2 Bar-Map Sensor?
Old May 23, 2012 | 08:48 AM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Default 2 Bar-Map Sensor?
Can someone please confirm what the GM part number is for a 2 bar map sensor? Also how much boost can a 2 bar support versus a 3 bar. I understand a 2 bar has better street-ability and easier to tune then a 3 bar.
Thanks in Advance.
Old May 23, 2012 | 08:50 AM
DSteck's Avatar
DSteck
2 bar can do ~14.5 psi. 3 bar will do about 30. The operating system you use will dictate the resolution of the table.
Cars are still perfectly streetable with a MAP sensor that has greater range than 2 bar.
Old May 23, 2012 | 09:39 AM
Sponge Vette
Thanks for the reply Dsteck, never heard of a 2.5 Bar sensor. Is this a 2 bar modified and what kind of boost can it support?
Old May 29, 2012 | 01:55 PM
DSteck's Avatar
DSteck
22psi, it's a modified stock sensor.
To 2 Bar-Map Sensor?
