update on problems, still need help.
May 30, 2012 | 10:07 PM
Switched out the Tstat and Water pump, Car is still running hot around town (gets up to 230). On the highway I'm fine, but anytime else it's still running hot. Both fans are working and i'm noit getting any codes.
Any ideas? Bad radiator?
This is driving me crazy
May 30, 2012 | 10:39 PM
Didn't see the other thread. Did you burp the coolant?
May 30, 2012 | 11:07 PM
Quote:
Originally Posted by
Milan
This is the only thing it can be man. From what you have said here. You have a air pocket in the system and it is not circulate the water thur.
May 30, 2012 | 11:19 PM
Didn't see other thread but could very easily be a clogged radiator.
May 31, 2012 | 10:19 AM
The tune's been changed from stock regarding the fan settings?
May 31, 2012 | 11:07 AM
LPDesRoche
Also check your air dam - if it is damaged or gone - then that could also cause the problems your describing
May 31, 2012 | 04:07 PM
Also try cleaning off the radiator.
May 31, 2012 | 04:36 PM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Both fans are working - BUT are they hitting the Hi-Speed that you can tell?
What again brought on this issue? What if any changes from the time all was working properly?
Thanks,Matt
May 31, 2012 | 11:34 PM
LPDesRoche
If it was are started running hot and you chged the 2 things that you said and checked what I told you to do are look at. Then more than not it is the RAD. Robert
