Nitrous Install "Build Thread"/Tutorial
Old Jun 20, 2012 | 10:25 AM
JuicedH22's Avatar
JuicedH22
Default Nitrous Install "Build Thread"/Tutorial
I guess I should link this build to this sub-forum as well.
http://forums.corvetteforum.com/c5-t...ld-thread.html
http://forums.corvetteforum.com/c5-f...intensive.html
Old Jun 22, 2012 | 11:11 PM
JuicedH22's Avatar
JuicedH22
A few more pictures added....
Just waiting on some vinyl decals. I got the ones i ordered in the mail... turns out that 0.25" is bigger than I thought it would be, so need to find somewhere who can do smaller.
As far as details:
N2O purge
N2O window switch
N2O FPSS
DynoTune pressure gauge
HSW 90mm plate
HSW auto bottler warmer
HSW n2o solenoid
NOS bottle opener
custom switches/wiring
Old Jun 23, 2012 | 01:46 AM
kris6868's Avatar
kris6868
sweet setup
Old Jun 23, 2012 | 06:37 AM
dankhts's Avatar
dankhts
Very pro looking installation...awesome job!.......I'm on my way over to get you to do mine!
Old Jun 23, 2012 | 10:44 AM
elerico's Avatar
elerico
did you have some issue with this bottle ?
cuz the bottle isn't facing the front of the car
Old Jun 23, 2012 | 12:03 PM
JuicedH22's Avatar
JuicedH22
No issues. While the placement isn't optimal (like bottle facing front). I have it at the appropriate 45deg tilt. It is mounted the way it is, so that I can cover the bottle with the trunk cover I am fabricating.
Old Jul 23, 2012 | 12:01 PM
JuicedH22's Avatar
JuicedH22
adding link to purge line installation
Old Jul 23, 2012 | 12:42 PM
Rob Petyo's Avatar
Rob Petyo
Very nice set-up!
Here is an idea for you, if you haven't decided on something else already. I wanted the same thing but to be able to remove the bottle and place the covers back in place.
Old Jul 23, 2012 | 01:27 PM
JuicedH22's Avatar
JuicedH22
Where did you get your bottle valve? Mine only has 1 extra port, and clocked to be over the label.
Old Jul 23, 2012 | 02:34 PM
Rob Petyo's Avatar
Rob Petyo
That’s a four port, unless you are going NANO, you really only need a three. I have the old three if you are interested and a B/D tube.
Nitrous Dave has everything you may need!
I haven't actually run my N02 yet, the last time we were at the track it was hot and my system didn't work. It ended up getting too hot and the bottle purged on me (my lack of experiance). I’m planning on using it this coming weekend during the East Coast Supercharging Corvette Challenge, 10.50 index class. We checked it all out this past weekend and it looks like a GO for me.
Note on safety:
Do not plan on leaving your bottle (full) in there like that in the summer heat without checking your gauge pressure often, I think inside there and closed up might get a bit warm.
Old Jul 23, 2012 | 02:48 PM
JuicedH22's Avatar
JuicedH22
Yea, I definitely dont plan on leaving it in the car full, or even partially full, and closed.
In fact, it is funny you mention it, because I forgot to take the bottle out before coming to work this morning, and had to bring the bottle into the office.. which brought a few odd looks and some laughs from those that knew what it was, haha.
And I already have a 3 port, but may upgrade to a 4 port in the future.
Old Jul 23, 2012 | 03:13 PM
jerrad's Avatar
jerrad
Wow, great job. The install looks near factory. What size shot are you gonna run?
Old Jul 23, 2012 | 03:24 PM
JuicedH22's Avatar
JuicedH22
100 or maybe 125 dry shot
Old Jul 23, 2012 | 05:36 PM
jerrad's Avatar
jerrad
Dry? I thought you had to spray before the MAF to run a dry kit.
Old Jul 23, 2012 | 06:10 PM
JuicedH22's Avatar
JuicedH22
Nope, that's not true these days. There are controllers such as the HSW "the interface" that will plug and play into the MAF/IAT and when the n2o is activated it will make the IAT set to like 198 deg or some value, and you use your tuning software to make add the appropriate amount of fuel at that point
OR what I did was use COS5 and it's nitrous/FI tables to directly add fuel and cut timing when the 2nd stage of the window switch is activated.
I run speed density and don't even have a MAF sensor anymore.
Old Jul 23, 2012 | 10:48 PM
jerrad's Avatar
jerrad
Very cool. So do you have nitrous going into both sides of the plate?
Old Jul 24, 2012 | 11:32 AM
JuicedH22's Avatar
JuicedH22
Yes, I have a t-fitting coming off of the n2o solenoid, feeding 2 -3an lines that go to each side of the plate (it was a "dry plate kit" so it had the lines and jets already).
To Nitrous Install "Build Thread"/Tutorial
