View Poll Results: How's your motor doing after your supercharged...
Still stock running great!
71.88%
It blew up after xxx miles...
12.50%
I had it rebuilt/modified before I put the charger on
12.50%
Other...please state your specifics
3.13%
Multiple Choice Poll. Voters: 64. You may not vote on this poll
Supercharger to Engine Reliability Poll
Old Aug 10, 2012 | 07:11 PM
Warp Factor's Avatar
Warp Factor
Originally Posted by Lloyd Christmas
Nope. Completely stock engine. Just looks like bad luck. Block cracked, water got in the cylinder, broke the piston.
Nope. This was about 2500 miles after we put the supercharger on and tuned it. I don't think it had anything to do with the tune. The other cylinders and pistons looked fine, no signs of detonation.
Water got in the cylinder and cracked the block? Maybe you broke a piston, and that cracked the block.
It's fairly normal to only have failure on one or two cylinders, and the rest look fine. And it can happen without obvious signs of detonation, since it usually requires sustained detonation to produce a typical detonation signature.
There's a threshold where detonation and excessive combustion temperatures don't blow off metal, but can produce enough heat to butt the ring end gap and pull off the ring land, especially on stock emissions engines with narrow ring gaps. Anything can happen after that, when you've got loose metal floating around in the combustion chamber, maybe being squeezed in the small quench area where there isn't enough room for it.
I've got seven years on my stock longblock ECS supercharged engine. I probably didn't go with the cheapest tuner, or the one who told me everything I wanted to hear, but no regrets.
So what I'm suggesting is that it very well may have had something to do with the tune.
Old Aug 10, 2012 | 08:29 PM
Lloyd Christmas's Avatar
Lloyd Christmas
Anything is possible.
Old Aug 10, 2012 | 08:30 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I went from 319 RWHP to 749 to 771 RWHP. I dropped in an A&A 347, West Coast LS6 heads chambered to 72cc, 9.25 compression. DS1C. I ran the snot out of it. Did over 190 mph at the Texas Mile. Put 20+ k on it and when I wrecked it my motor was running strong.
Old Aug 10, 2012 | 09:49 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I am running close to 600 to the wheels with 12 lb boost. A
excellent tune and meth are the key. I guess I have about 5
years on the motor. Oh yea I never get hot and I live in
Florida, that helps too.
Old Aug 10, 2012 | 10:06 PM
Warp Factor
Sure, but the next step is to figure out what's probable.
Which cylinders usually fail on LS engines? Is it a cooling problem, or an air distribution problem? What role does the tuner play in either or both?
Old Aug 10, 2012 | 10:50 PM
Lloyd Christmas
5 and 7. What indications of air distribution or cooling problems would you look for? What would indicate a tuning issue to you?
Old Aug 10, 2012 | 10:59 PM
JustinStrife's Avatar
JustinStrife
2000 LS1 was supercharged at 107k miles with a used Procharger D1 kit February of 2007. I sold the car in September of 2011, she had 134k miles but the old motor was tired. Was using oil, one of the rings was shot, but she had a hell of a run for never having touched the longblock.
I'm onto bigger and faster C5s now.
Old Aug 12, 2012 | 10:24 PM
C5XTASY's Avatar
C5XTASY
ttt
Old Aug 13, 2012 | 08:34 PM
Quick 06's Avatar
Quick 06
627 rwhp with a V3 and Cam. It's like any other modification, if drive it reasonably and respect the power at hand, it will last. I've had mine on road courses and snuffed several weekend warriors from the dig with no issues.
Old Aug 14, 2012 | 12:01 AM
a/c man's Avatar
a/c man
Originally Posted by East Tx Muscle Cars
True! the Tune has a TON to do with it. You can run 525-575 RWHP for a VERY VERY VERY long time on your stock motor. What it comes down to really is boost level and tune. If we do a build and we put it t 7-9 PSI ill tell my customer to drive it ANYWHERE and dont worry about it, when you start getting over 10 PSI your really pushing a stock motor. Not saying it wont last , but thats alot of boost on the motor that was not made to handle that much.
Yea @ 10psi my car with your tune went KABOOM!
Old Aug 14, 2012 | 12:08 AM
a/c man's Avatar
a/c man
Seems like ring gap plays into factor here (warped factor)so I see more high mileage motors do better the ring gap gets bigger with wear when the rings get hot and the gap closes and but up the piston cracks and you loose ring lands
Old Aug 15, 2012 | 03:09 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
East Tx Muscle Cars: when you start getting over 10 PSI your really pushing a stock motor. Not saying it wont last , but thats alot of boost on the motor that was not made to handle that much.
he did mention that at 10 you were pushing it on a stock block...so curious why didn't you back it down to 5-8?
Old Aug 15, 2012 | 03:27 PM
  #33
JLayer's Avatar
JLayer
Installed mine around 39k..just now passing 41k. 8psi/579rwhp. I give it hell everywhere. No meth either. I'm expecting at least minimum 5k before looking at a rebuild.
Old Aug 15, 2012 | 05:24 PM
  #34
robert miller's Avatar
robert miller
newbie
Old Aug 15, 2012 | 08:52 PM
  #35
bradf74's Avatar
bradf74
this is an excellent thread. i am considering a stock 03 with 38k for a supercharger. i want 500 hp but NO reduction in reliability. I can get the car for about 18-19k i think and I will have another 7-8k in total mods to the motor and clutch. i want to get the work done myself rather than buy a modded car. just think I will trust it more if I start at mile 1 with the mods. keep the stories coming guys...
Old Aug 15, 2012 | 09:32 PM
  #36
ajrothm's Avatar
ajrothm
Supercharged at 23k miles, Installed by a professional shop that used to reside in Houston (MTI)...10 psi, made 604rwhp originally. Added meth (non meth dependent tune) and it made 622rwhp.... At 27.5k miles it broke ring lands on #5 and #7. Always watched the wideband and never leaner then 10.8-11.0......
The rebuild has tuned into a 6 month long, $30k build odyssey...
Many live, many don't, even with every safety precaution taken and good tuners involved...
Knowing what I know now, I wouldnt go over 7-8 psi on a stock motor and definitely have meth. I still think the stock hypereutectic pistons are ticking time bombs... Just WAY too many LS1s/LS6s have killed #5/7 pistons.
You also have to look at how its driven.... Most of the guys getting 20-30k miles boosted on stock engines are NOT running them hard.... Going through the gears once or twice a month and just about anything will live.... But if you pound on it every weekend they are on borrowed time... Time means nothing and even miles don't mean a lot....whats more important is the usage.
Old Aug 15, 2012 | 10:23 PM
  #37
Quickshift_C5's Avatar
Quickshift_C5
Reading some of these posts is terrifying.
Really makes me wonder about the reliability of my own motor with the A&A Kit on it running at 10psi (572/482). It's too late to go back now, but I can't help keeping my fingers crossed until I get the chance to swap in a built bottom end.
To Supercharger to Engine Reliability Poll
Old Aug 15, 2012 | 11:05 PM
  #38
robert miller
But meth on it at that power and dont totally DOG the car with a good tune. You should be good man. Robert
Old Aug 16, 2012 | 11:24 AM
  #39
XtremeVette
very VERY well said. I wish I had re-written the post to be better summarized the way you put it....not so much mileage as "usage".
I think and hope I will be more on the safe side of the dark side. I take mine out usually on weekends for car shows or going on trips (vacation). For me I don't consider what I do playing with it hard. In fact the car has never seen 6,000 rpm's. I owned a C4 prior to the C5...5500rpm's feels like it is screaming cause the C4 topped out at 4500rpms. So much of my driving I find that I am shifting before that 4500 figure. Of course every now and then I bring it up 1000 more and shift at 5500rpms. But yeh that's it for me...just have had no feelings as to why push it to the 6000 redline.
Old Aug 16, 2012 | 12:41 PM
  #40
2bridges's Avatar
2bridges
stock LS6 going strong at 10PSI + single nozzle meth -stock (except valve springs)
10K + miles
18 standing mile runs to 180mph
aprox 24 1/4 mile passes
60 mile SORC open road race (all at 5,000 +rpm)
Car sees 6500rpm on a regular basis, limiter set at 6700rpm
