Who makes High Impedance 90+lb Injectors
Looking for 90ish lb/hr injectors for my boosted setup but in a high impedance. I currently have 95lb racetronix Low's with the plug and play injector driver box. I want to clean up the wiring a bit and get rid of the driver system. Who should I look to for 90+lb high imp. injectors? It can have a Jetronic/Minimeter or USCAR clip on it, I can get the adapters. I'd really like a set of EV14's but having trouble finding them.
Former Vendor
ISIS SUCKS FAT CHOAD
Can't go wrong with Injector Dynamics ID1000's or FIC1000's (quite a bit cheaper then the Injector Dynamics Injectors). I personally run the ID1000 injectors.
Another vote for the ID1000's. I just installed a set and have been tuning them this week. They run smoother than the 60's that I removed.
Former Vendor
We've used the FIC 1000's, FIC 1200's and FIC 2000's-and have the proper HPT data to get you going.
I am currently running the extended tip F1C 1200's ( Bosch racing 127's ).
They are great for intakes such as Fast where the injector is moved up alot higher than stock.
