P0410 code after mods installed
Old Oct 1, 2012 | 12:41 PM
mig1980's Avatar
mig1980
Default P0410 code after mods installed
Figured I would post here as well since it started happening after the car got boosted. Below is the original thread.
http://forums.corvetteforum.com/c5-s...fter-mods.html
Old Oct 1, 2012 | 04:58 PM
02402ramair's Avatar
02402ramair
p0410 shows to be a air pump code. Since you are in CA you will more than likely have to have this working. I have seen many AIR pumps go bad. I would check all AIR hoses and valves and see if you hear the pump run on startup.
Old Oct 1, 2012 | 05:09 PM
mig1980's Avatar
mig1980
How does it sound and when would I hear it run (when the engine is on, or when key is in on position but car not started)?
Old Oct 1, 2012 | 09:38 PM
02402ramair
With car running and motor cold
Old Oct 1, 2012 | 09:39 PM
02402ramair
If they don't test for it you can just turn off the codes for A.I.R.
Old Oct 1, 2012 | 10:56 PM
mig1980's Avatar
mig1980
I have no clue if the test for it here or not. I turn the key to the on position and I can hear some sort of charging noise. Not sure if that is the pump. I am unsure what else I am suppose to hear?? This is very frustrating because all of this was working properly prior to the mods.
Old Oct 1, 2012 | 11:41 PM
a/c man's Avatar
a/c man
welcome to a boosted car world its just a air pump under the front driver side head light only comes on when your car has a cold start. its for smog! make sure its still plugged in. it sucks ex from the ex. manifolds and hooks to the stock air filter box its probly unpluged now!
Old Oct 2, 2012 | 12:09 AM
mig1980's Avatar
mig1980
All seems to be plugged in but I haven't gotten under the car. The installer told me today that he had connected everything back up although we did change the valley cover, heads, valve covers, intake to an ls6 from 98 ls1.
Would I hear the humming that the pump makes while the car is on or is the humming I hear when the ignition is in the on position (for a few seconds)?
Old Oct 2, 2012 | 12:20 AM
a/c man's Avatar
a/c man
only when car is running cold start for 2 min...
Old Oct 2, 2012 | 12:37 AM
mig1980's Avatar
mig1980
I'll have to start it up tomorrow and see if I hear it.
To P0410 code after mods installed
