Injector settings
I have a stock LS1, meaning stock cam, heads, rockers, rotating assembly etc. It does have a twin turbo kit, LS6 intake, 1:1 regulator, and return style fuel system.
I am using hptuners with a 3 bar SD OS and ID1000 injectors. I have input the correct short pulse, offset, flow rate, etc., from Injector Dynamics.
Now let's only discuss idle and low speed part throttle conditions. From an airflow standpoint, it should be relatively close to stock, but I have adjusted the VE table based on the AFR error histogram and there isn't a stock value in my entire map now.
Greg, would you say this makes sense, or do I have errors somewhere else?
Is it correct to look at the VE table as a way to get your fueling dialed in instead of an airflow model? Basically I am treating the VE values as fuel required instead of theoretical airflow.
I personally think this needs to be tackled, even if not perfect, because C5/6 can see large voltage fluctuations and also get a decent base offset… This can be frustrating first time around, so you decide.
Short pulse adder is last step IMO.
"rated at 750cc ( 71.4 lbs/hr) at 43 psi. The maximum fuel pressure is up to 70 psi. The injector will continue to sustain operation beyond 70 psi, but you will not see an increase in flow. The injectors require a 1 amp signal and should be fine with the drivers used in the factory ECU.
Here are the injector latency values for the SH4-750:
10v 1.36ms
11 1.12
12 0.92
13 0.76
14 0.63
15 0.50"
I don't have my laptop with me, but where would latency values be entered at? Sorry if thats a dumb question with an obvious answer.
They match your linked chart as well.
Google “Data Fit” as I think they still have 30 day free trial (select 3rd order polynomial for regression method), this will build curve fitting equation for you. NOTE with only 6 data points (10-15V) anything outside this range will be error prone. You need Microsoft Excel. This will help extrapolate offset vs voltage outside supplied data.
If you are comfortable to this point, shoot me a PM and I’ll help with the rest. Again will not be dead on, but better than where you are now.
...but I have adjusted the VE table based on the AFR error histogram and there isn't a stock value in my entire map now.
Also, I see a lot of confusion between "offset" and "deadtime" or "latency". They are NOT the same. When properly used, injector offset includes both the opening delay and the closing delay, showing a net value to adjust the final pulsewidth. A lot of aftermarket injector warehouses miss this because they seem to have no clue about the engineering that goes into the product they are selling. Unfortunately, if they give you a big ol' pile of steaming crap for data and some fast talk about latency, most consumers don't know the difference. There is a short list of companies that are selling injectors and actually understand them and how they should be characterized in your corvette. Injector Dynamics happens to be one of those, and I trust the data coming from Paul Yaw because we've had lengthy discussions about how it's generated.
I do own one of your books and have watched some of your youtube promos in the past and that is where I equated offset = latency...
Did a quick search and http://www.youtube.com/watch?v=kBk0K...endscreen&NR=1 at about 4:15 appears to say same thing.
I have no dog in this fight, so I’m out.
The gap you see is mostly deadtime or latency, but that's what it takes to get over to the physical mass vs time curve/line. Closing delay is hard to visualize in that graph, but it's there in the form of mass that is added at the end of the pulse. All we really care about is total milliseconds of activation time and total milligrams of fuel mass, so using a single value for "offset" does it very cleanly in this case.I'm glad people are actually paying attention and starting to ask more intelligent questions about this. It will force the injector suppliers to raise their game. As the consumers, you guys ultimately benefit.
Now I'm curious how one comes up with the "short pulse adder" and further more, why is that needed? I thought the "offest vs. volts vs. vac" table would take care off any offset/latency. No? Also wondering how one calculates the "short pulse limit" and "min injector pulse"?
The short pulse limit defines the area in which we apply the adder. It is usually just left to 4.0ms in GM calibrations, since we can always just add a zero if there is no change needed.
Min injector pulse is used to clip the bottom end to a value where we actually have repeatable control of delivered fuel mass during the commanded pulse width. There is a point where you just don't get consistent fuel delivery on the bottom end because you're not consistently opening the injector before you shut the field down. If it only opens part way, you have no clue how much fuel you've delivered (if any). Setting this to a reasonable minimum makes sure that if we fire the injector at all, we at least get something out of it.
Gee, how many other professional trainers or tooners do you see on here giving this info away for free? Do they even understand it themselves?
The gap you see is mostly deadtime or latency, but that's what it takes to get over to the physical mass vs time curve/line. Closing delay is hard to visualize in that graph, but it's there in the form of mass that is added at the end of the pulse. All we really care about is total milliseconds of activation time and total milligrams of fuel mass, so using a single value for "offset" does it very cleanly in this case.Quote - “The injector offset can be described as either the intercept of the high slope with zero fuel mass or as the point at which the injector really opens (where the low slope intercepts zero fuel mass). Similarly, GM also uses a short pulse adjustment to make up for the lack of a second injector slope at low masses. Both strategies get the same job done and allow the PCM to properly meter fuel at small pulses in the nonlinear flow region of the injector’s capacity.”
Not trying to be a jack azz, but there’s allot of contradiction here.
Again no dog in this fight, last post here.
So how does one calculate what short pulse adder is needed and what the minimum injector pulse and default injector pulse are?
Justin
We have in stock if necessary. RC's are out dated and do not include all the data necessary as I said earlier in this post.
