A&A Install help thread.
Old Oct 7, 2012 | 11:11 PM
Native's Avatar
Native
Default A&A Install help thread.
Trying to get the car ready for install and will be needing some help.
Going to post random questions in here.
At this point I have the plugs changed. I have removed the cai, maf, radiator shroud, fans, sway bar bolts and about a pound of dirt that was stuck between the radiator and condenser
I'm stuck on the step where you have to disconnect the rod end.
The directions say is Step "2.4 Loosen the 18mm nuts that connect the rod ends of the rack to the steering knuckle."
Am I supposed to remove both of the upper and lower 18mm nuts on the rod ends? (see pic below) Am I supposed to remove them on both sides?
Also, what does it mean by "steering knuckle".
Old Oct 7, 2012 | 11:24 PM
Native's Avatar
Native
The idea is to drop the sway bar down enough to pin the crank.
Couldn't I just remove the bolt (red arrow) and drop that passenger side sway bar down enough instead of popping out the tie rod end?
Old Oct 7, 2012 | 11:31 PM
backnblack2003z06's Avatar
backnblack2003z06
The nuts you want to remove are the ones that connect the tie rod ends to the steering knuckle. In the pictures it looks like the wheels are still on the car, you need to take them off to get to the nuts. You have to remove the steering rack not just lower the sway bar to get to the balancer.
Old Oct 7, 2012 | 11:37 PM
backnblack2003z06
The green arrow points to the nuts you want to remove, they are just outside the picture.
Old Oct 9, 2012 | 01:50 PM
Native's Avatar
Native
Ok, so tie rod end ended up being very easy after getting the wheels off. I also got the power steering cooler off and moved out of the way.
Now it looks like there is two bolts that hold the steering rack in place and one steering shaft bolt. After those three bolts are out, the steering rack should be able to be slid out of the way, correct?
Old Oct 9, 2012 | 07:37 PM
big454blockchevy's Avatar
big454blockchevy
I am doing the install also on the vette. The rack once you get the hydraulic lines disconnected pushes to the driver's side and you can lift up the passenger out of the way. I'll take a pic and post it later.
Old Oct 10, 2012 | 10:44 PM
big454blockchevy
pic added
Old Oct 10, 2012 | 10:58 PM
Native's Avatar
Native
Thanks for sharing a pic. I got it all disconnected. Just need to borrow a large breaker bar tomorrow to break the bolt loose.
Old Oct 10, 2012 | 10:59 PM
Native's Avatar
Native
Got my kit today!
Was curious about this line coming off the supercharger though. I bought the "Self Contained" unit. What is the line coming off the headunit for?
Old Oct 10, 2012 | 11:09 PM
backnblack2003z06
Oil drain.
Old Oct 10, 2012 | 11:14 PM
Native's Avatar
Native
Originally Posted by backnblack2003z06
Oil drain.
For when you change the supercharger oil?
Is it just supposed to hang there? lol
Old Oct 10, 2012 | 11:33 PM
Chrisrokc's Avatar
Chrisrokc
I just zip tied the line to the power steering hard lines. Makes for an easy oil change and keeps it away from the belts.
Old Oct 13, 2012 | 06:16 PM
Native's Avatar
Native
Install was put on hold. The "rear supercharger bracket" has a bolt that goes into the head. I couldn't get the bolt to go all the way in. We triple checked that it was the correct bolt. Figure we will have to tap the bolt hole and clean a build up of dirt out to get the bolt in. Anyone else have trouble with this?
Old Oct 16, 2012 | 10:38 AM
Nathanknorr's Avatar
Nathanknorr
Thanks for this thread, it is helping me with my decision on whether to turbocharge or supercharge my car, so far its looking like this is still an easier install.
Old Oct 16, 2012 | 11:58 PM
Native's Avatar
Native
Supercharger is mounted!
I'm working on the long tube that connects the 3" aluminum piece off the supercharger outlet and the intercooler. Does this go under the sway bar or on top?
Any pics out there?
Old Oct 17, 2012 | 12:01 AM
Milan's Avatar
Milan
I'm pulling my car apart tomorrow to cam it I will take a pic if you no one responds sooner!
Old Oct 17, 2012 | 02:15 PM
Native's Avatar
Native
Any pics out there?
http://forums.corvetteforum.com/c5-f...ng-myself.html
LoL I started a thread expressing concern about taking on this project.
Everybody says "do it, we are here to help". Then I can't even get a couple easy questions answered now that I started installing.
To A&A Install help thread.
Old Oct 17, 2012 | 02:54 PM
Chrisrokc's Avatar
Chrisrokc
Didn't see those questions....
I had some problems with one of those bolts are well. I cleaned the threads with a small wire brush and wd40. I then sprayed wd40 on the bolt without trying to mount the bracket. After I turned it in significantly I started to use a socket wrench. It was a little tough, but after taking it in and out a few times I went ahead and mounted the bracket with sc.
That tube should go below the sway bar I believe. I will look when I get home and post if different.
Old Oct 17, 2012 | 03:13 PM
Native's Avatar
Native
Thanks a lot I appreciate it.
We ended up getting the bolt in after spraying high pressure cleaner in the hole. Bunch of dirt and crap came out.
I'm going to finish the charge piping tonight.
Old Oct 24, 2012 | 10:43 PM
Native's Avatar
Native
Getting pissed with this damn install.
The directions are vague in areas that I need a little clarity.
The connection from the intercooler to the throttle body is hazy. According to the instructions, this is how it should look. What am I missing here?
