ALKY control question
Old Oct 31, 2012 | 03:31 AM
Zeus-of-Boost's Avatar
Zeus-of-Boost
Default ALKY control question
when I test my alky kit while sitting in the drive way ideling, the rpms actually increase. it does not bog the motor down. what's up with that. ?? I'm spraying washer fluid and 2 bottles of "heat" I that helps.
Old Oct 31, 2012 | 09:35 AM
StatmanRN's Avatar
StatmanRN
If you were running straight meth, I would say you were running a bit lean at idle, like a vaccum leak.Mine stumbles a bit on test on meth when tested.But Im on the rich side.
