boost LEAK TEST help
Old Nov 4, 2012 | 06:34 PM
Zeus-of-Boost's Avatar
Zeus-of-Boost
Default boost LEAK TEST help
here is my set up
but i can only hear air seaping out of my brand new supercharger here..wtf
This is what my compressor is set on
1. is air supposed to seep out of the supercharger there ?
2. AM I DOING THIS RIGHT ??
Old Nov 4, 2012 | 07:52 PM
turbo402's Avatar
turbo402
you need to leave everything hooked up and pressurize the system through the super charger inlet. What you have going on there is going to do nothing to help you determine if anything is leaking.
Old Nov 4, 2012 | 07:53 PM
turbo402's Avatar
turbo402
also go about 5-10 psi above your max boost you def dont want to be shooting 30 psi through it for no reason.
Old Nov 4, 2012 | 08:14 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
If there's is air leaking at the volute that tells you there are no leaks from the intake pipe to the blower.
The air your hearing at the volute is coming from the holes that clock the volute-that's 100% normal. The holes go right into the scroll.
Another thing you should check is all the vacuum lines coming off the intake. Pull the line at the T-from the brake booster and use a mightyvac and put boost to the line.
This will verify there's no leaks at the meth map sensor, bov, etc, etc,,,
What problem are you having buddy?
Old Nov 4, 2012 | 08:29 PM
Zeus-of-Boost
ok so my pipes ect ect are all good. so now ill hook eveything back up (except the sc intake) and pressurize infront of the blower intake. gottcha
thanks
Old Nov 4, 2012 | 08:33 PM
Zeus-of-Boost
not really have troubles, just want to make sure everything is right. ok tomorrow ill check all my "lines" like you said. thanks dude
Old Nov 4, 2012 | 08:36 PM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
I would recommend keeping the intake involved in the test too. The volute can actually leak a surprising amount through those little 1/4" holes. I prefer to put 1/4 x 20 set screws in there with blue loctite. That's a little something that I learned from 02402Ramair. On AJRothm's car, I had an unregulated 3/8" hose with 120psi in the compressor tank and I couldn't get it to register anything until I put the set screws in. Once you do that, then you can start evaluating the rest of the system for leaks.
Old Nov 4, 2012 | 08:46 PM
Zeus-of-Boost
yes, i need the intake involved is this as well
im not pulling the supercharger back out of the car for the 50th time to install the screws in the volute. guess im going to bypass the blower all together. maybe cap the "blower exhaust" piping.
Old Nov 4, 2012 | 08:49 PM
4DRUSH's Avatar
4DRUSH
So you guys are saying the un-used threaded clock screw holes go thru the volute & leak?
Interesting
Old Nov 4, 2012 | 08:53 PM
Supporting Vendor
I pulled the volute off and left the rest of the blower in place. Use a marker to mark the position of the volute so you don't have to guess exactly where you had it.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Old Nov 4, 2012 | 08:54 PM
Supporting Vendor
Interesting
Yes, but only on some of them. Alan's F1R they all went through. My F1X, none of them leaked. I'll check the F2 when it arrives soon.
Old Nov 4, 2012 | 08:57 PM
4DRUSH's Avatar
4DRUSH
I thought the F1X was an F2, just re-named ??
Old Nov 4, 2012 | 09:03 PM
Supporting Vendor
Not really. Shane is the only person that I know of that's run both and he gained some boost on the change. I am also getting a custom 4.5" intercooler, 2400CFM intercooler made. Gonna get some air to this motor of mine one way or another.
Old Nov 4, 2012 | 09:22 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
Interesting
Not enought to make a difference-last thing you want is a set screw going into the volute. If you locktite them they are real hard to remove.
Just flatten the threads on the set screw so the only go in so far-they can back out-but not go in.
Old Nov 4, 2012 | 09:30 PM
4DRUSH's Avatar
4DRUSH
I see what you're saying. Maybe countersink the hole & use a flat head screw.
To boost LEAK TEST help
