Meth Setups
Old Feb 21, 2013 | 11:19 AM
junk c5's Avatar
junk c5
Originally Posted by 02402ramair
I have there trunk mount kit in one of my shop cars. The setup came with plastic feed line and it melted. Caused the car to detonate and blew a head gasket. We ended up getting a stainless feed line to replace the cheap plastic line so figure that into your decision.
I actually have their 1st series kit on my 1000 hp turbo mustang. It's been working well for the last 5 years. It just seems like most vette guys use everything but the AIS kit. Seems like vette guys are a little particular on their parts.
Old Feb 21, 2013 | 12:48 PM
02402ramair's Avatar
02402ramair
I will say that we have not had any other issue out of the kit other the plastic line melting. Pump,tank and controler seem to be real nice. We have had it for 4 years or more.
Old Mar 18, 2013 | 02:30 PM
jessejay356's Avatar
jessejay356
Anyone still using a MAF setup? Pics please... trying to decide what I need to do.. don't want to spray before MAF, and the current setup doesn't leave a lot of room to get it done.
Thanks,
JesseJay
Old Mar 18, 2013 | 03:27 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by Johnny08
The safety features usually work like that (constant down from certain IAT), but there's a lot more in a tune than that. That's why I'd like to see real IATs rather than something that is due to spraying directly to the sensor...
Would like to see ECS comment the nozzle vs. IAT placement...
IAT placement is done for the safety tuning factor. 99% of the people with meth have no idea what their IAT's would be at WOT pre meth or post meth, but everyone knows the effect of a blown engine.
Old Apr 5, 2013 | 03:27 PM
jessejay356
Bump... still looking for info on Meth setups running MAF.
Old Apr 5, 2013 | 03:52 PM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
If you are making enough power to need meth then you are more than likely pegging the MAF and need to go speed density. Any reason why you are keeping the MAF?
Old Apr 5, 2013 | 04:13 PM
jessejay356
My tuner says I'm not maxing the MAF. I'm at 460 rwhp right now, on way to 550 rwhp. Even with intercooler my IAT is high, and also crappy 91 octane fuel around here... trying to avoid any knock issues Also, my tuner is not so keen on SD Tunes for street cars.
Old Apr 6, 2013 | 07:38 AM
liveaboard74's Avatar
liveaboard74
And we even learn something every once in a while when we switch to straight meth over water/meth ...
Use the washer tank. Fiddled with the float and just another toy to see the light come on letting me know I"m getting low on juice...
What would we do without toys.
Meth on this side ,, that other stuff on the other.
Old Jan 28, 2014 | 10:30 PM
Phiber Optik's Avatar
Phiber Optik
When using the iat sensor for meth tune safety, has anyone seen the iat sensor fail? When they fail what does the ecu see? Failed high, failed low? Hopefully high then the safety factor would still work, my tuner claims 100% meth will kill the iat sensor quickly, so If we tune using the iat vs spark advance table I want to make sure if it does fail my motor doesn't go with it.
Old Jan 30, 2014 | 02:30 PM
Julio's Avatar
Julio
It will kill the MAF if you spray through it. IAT.. no way.. unless you take the sensor out and dunk it into a tank of meth and let it sit there for a few weeks.
12 years spraying on an IAT sensor.. zero issues with IAT.
Old Jan 30, 2014 | 02:58 PM
Mattie Num Nums's Avatar
Mattie Num Nums
Ooops wrong meth setup
Old Jan 30, 2014 | 04:11 PM
Milan's Avatar
Milan
Replying to this a year later so people don't read the thread and receive misinformation.
There IS NOT more to it than that. When meth is spraying that means you are in boost, which means as far as your PCM is concerned you are in "power enrichment mode", meaning that the PCM isn't referencing that "a lot more to the tune" section you are talking about here.
Also for you accurate reading ***** out there, you have to understand how this works. When you spray the meth into the intake stream it atomizes instantly, it's not like peeing into the wind. Nothing is entering your motor in liquid form.
The air cools down instantly and then a split second later it's combusted.
Old Jan 30, 2014 | 07:54 PM
  #33
leo12's Avatar
leo12
It would be nice to have some better looking fitting other that the Home Depot stuff it comes with. JMO
Old Feb 10, 2014 | 07:35 PM
  #34
JeremiahsC5's Avatar
JeremiahsC5
I am glad I read this. I am upgrading my intercooler and supercharger intake pipe to 4". I was thinking of upgrading to dual alky nozzles and after reading this realized I had my alky nozzle after my IAT sensor. Is there any performance gains by putting the nozzle before. I am going to run dual nozzle. Any performance gains by doing this as well. Thanks in advance.
Old Feb 10, 2014 | 07:59 PM
  #35
PhysicsDude55's Avatar
PhysicsDude55
I think the argument is that on an SD tune, the PCM is calculating the air mass by computing the air pressure and air temperature (to extrapolate air density), so even though the air is being cooled, does it really mean that the incoming air density and air mass has changed? I don't really know, just posing the question.
Nevertheless I think its a moot point. If the meth is spraying, that means you're in power enrichment mode, and nuanced stoichiometric calculations go out the window and you richen the motor up to 10.5:1 or 11:1 or whatever to get the most safe power you can. Who really cares if the IAT based PCM calculations are off by a bit? You'll just even out the fuel/air ratio by adjusting the PE table anyway. WOT tuning is the easy part, the other tuning takes more finesse, and the meth isn't involved in that tuning, so you'll get "clean" IAT readings.
Old Feb 10, 2014 | 08:04 PM
  #36
PhysicsDude55
I don't think you'll notice a performance difference, just that putting the nozzles before the IAT will basically let you know if the meth is spraying, and you can tune the IAT table to pull timing when the IATs are too high as a failsafe.
I think its definitely a good idea. I think its the most practical and reliable failsafe method available.
Even if you buy a flowmeter guage or whatever to monitor the meth flow, by the time you're WOT or halfway down the drag strip, and you notice that your meth isn't flowing, its probably too late, you can't realistically react that quickly. Letting the PCM do it for you is better IMO, just make sure you're datalogging and looking at the data.
Old Feb 10, 2014 | 08:34 PM
  #37
JeremiahsC5
Thanks for the reply. I have the Alky Control Systems kit. I also happen to have an extra nozzel. The jets are stamped M15. Could I use them to build my own duel kit? If not I will order the kit from Julio.
To Meth Setups
Old Feb 11, 2014 | 07:40 AM
  #38
Julio's Avatar
Julio
How much power are you making to merit running a dual setup?
Twin 15's is typically north on 900 rwhp..
Old Feb 11, 2014 | 08:03 AM
  #39
JeremiahsC5
Last Dyno run was 715 rwhp. Installing bigger intercooler and 4" supercharger intake now. Should pick up some boost and a little more power. On a side note. my tuner has the gain **** on the meth controller at 4. When I hit the test button it stays red. If I turn it up and hit the test button it goes green. Wondering if the tune is so lite on meth. Smaller jet or running 2 nozzles is not needed. Thanks in advance Julio.
Old Feb 11, 2014 | 08:31 AM
  #40
Julio's Avatar
Julio
Once you get the gain **** up to 8.. and need more.. then is when you do the twin.
