Fast Intake ?
Old Feb 5, 2013 | 11:35 AM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
Default Fast Intake ?
How many of you are running Fast intakes? Thanks
Old Feb 5, 2013 | 12:28 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
If you are chasing every last bit of HP then it's worth it. Most guys just push a little more boost to get more HP. $900 is a lot for and extra 30-40hp maybe I'm guessing! Just my .02
Old Feb 5, 2013 | 03:35 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
I run a fast. But I like bling so I opted for it and spent the $
Old Feb 5, 2013 | 04:08 PM
fotoboy's Avatar
fotoboy
I had a ported fast before FI so I stayed with it. Fast tests there intakes to 35 psi so no worries.
Old Feb 5, 2013 | 04:37 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
Thanks just checking to see. I have seen a lot of FI guys going with the fast 102. Just wondering what their thought are. Keep them coming..
Old Feb 5, 2013 | 04:54 PM
fotoboy's Avatar
fotoboy
to me 30-40 hp is worth it it thats what people are getting.
Old Feb 5, 2013 | 06:23 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I have the fast 102 & NW 102 TB.Had it when I was NA so just reused it.
Old Feb 5, 2013 | 06:25 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I plan to get one.
Old Feb 5, 2013 | 07:07 PM
4DRUSH's Avatar
4DRUSH
Originally Posted by fotoboy
to me 30-40 hp is worth it if thats what people are getting.
but I doubt it's that much
Old Feb 5, 2013 | 08:10 PM
sabastian458's Avatar
sabastian458
What needs to be done to the fast for boost? What are yall doing with the map sensor on the back?
Old Feb 5, 2013 | 09:17 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
These guys got great numbers out of it..
Old Feb 5, 2013 | 11:10 PM
SBCGENII's Avatar
SBCGENII
That was turbo though. The wastegate will compensate for the the increase in VE and spin the turbo harder, centri will not.
Old Feb 5, 2013 | 11:13 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
936 rwhp. 14 psi. Take the intake apart and I check the seal because I have had some come in with the seal not installed properly. I loctite all the bolts and have run with it. Tested up to 20 psi and worked just fine. I dont recommend anything over that due to the runners trying to come apart.
Old Feb 6, 2013 | 07:06 AM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Get the map extension and run it in the front of the intake on top.I'll post a pic later.
Old Feb 6, 2013 | 10:06 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I have seen at least that on 750rwhp cars, and more on the TQ numbers.
You should get one if you want to keep up with the RPM boys this year in True street...
Old Feb 6, 2013 | 10:33 AM
robert miller's Avatar
robert miller
RPM boys pushing it hard this year... ton of cars out this year in almost ever class... Robert
Old Feb 6, 2013 | 12:14 PM
sabastian458
Ok, I have seen that kit to move it to the front. What are you using to plug the hole in the rear then?
To Fast Intake ?
Old Feb 6, 2013 | 02:22 PM
WrEcKeD1101's Avatar
WrEcKeD1101
Here's mine moved to the front. All i ran in the back were the lines to the brake booster. They give you the option to drill the back or front for the sensor.
Old Feb 6, 2013 | 02:35 PM
50_Dave's Avatar
50_Dave
My fast 90/90 went khaboom. The lower intake split in 1/2 down the bottem at around 12psi. I dont know if they have gotten better or not in the past couple of years.
Old Feb 6, 2013 | 04:51 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
A vacuum cap
