missing bracket part... can i wing it?
Old Apr 4, 2013 | 12:53 AM
fillintheblanks's Avatar
fillintheblanks
Default missing bracket part... can i wing it?
So it seems like I am missing the cylinder head spacer that has the ati supplied spring tensionor ,on my p1sc1 procharger HO KIT. I have the old bracket set up wit 4 pullies total on head unit . I am stumped on what to do. I don't feel like dumping 500$ into a new bracket. APPARENTLY THE PIECE I NEED is now a ghost part and is a mystical legend. What I hear from procharger....
Was thinking about making my own spacer and running mounting bolts straight to cylinder head so I have 4 solid points of contact...... Including the factory tensioner ones as two of the four. I am afraid I might be pushing my luck .... And end up bending some things.
Old Apr 4, 2013 | 06:58 PM
Arnie Chamberlain's Avatar
Arnie Chamberlain
Bolt the bracket up without the spacer, then use an inside micrometer to measure the distance from the bracket to the cylinder head. Then get a local machine shop to make you a spacer from a piece of aluminum bar stock sized for an M10 bolt to pass through on the inside diameter and at least 3/8" bigger than that on the outside diameter (3/16" wall thickness). A piece of 3/4" dia aluminum round stock with a hole drilled in it and cut to the right length would work great.
