Its a nice sunny day here in Michigan, believe it or not... Once in a while the sun comes out to greet us! Ha!
I am in the process of a build on my C5 and I have a question.
I have LS3 heads on my 6.0L LQ4, a LS3 intake manifold, what throttle body should I use? Should I run a LS3 throttle body? If so, where do I purchase a harness for the TB conversion.
Last but not least, would anyone be willing to trade me a throttle body that will work for me for my ported LS1 TB?
When I bought my Nick Williams 102mm TB it had a c5 style TB motor which I didnt know it was going to and worked out great. I dont know if there is 90mm TB with a c5 style motor but check on that. I bought my setup from Vengence and I remember back in the day Texas Speed also had TB setups including harness if you cant get a c5 style.
