Flip Drive AC belt slipping
Personally I would like to see the DD/flip/secondary drive guys logging RPM vs. voltage to prove to me the 4 rib isn't slipping.
The idea is great but having both my pumps wired to the alternator its not very reassuring to have the belt slip there
Here is 7100 rpms in high gear, voltage is 13.2 according to hpt..
looks like one more thing to add to he setup. rather nip it in the bud then to have issues later.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
^^^ thats what I mean, some guys say they have held the belt, I never have yet. It's very clear in the logs on everycar. Voltage drops like a rock to 11-11.3 as soon as the throttle fully opened. C5/C6 doesn't matter, and the belts were adjusted properly.
As soon as the pass was over, right back to 13.x, you would never even know it if it wasn't being logged.
I just went through 3 or 4 of my old logs, and on a couple of them, I did see the volts drop to 12.4-12.5v at 5000-6800 rpms... So I guess I get some slip SOMETIMES... The log I posted above was the last full highway blast I did so... Its not like the belt stretched or wore out of something...because it didnt slip that time. Maybe its a heat thing on the belt or something as well...
Guess thats something else I'll have to buy in the future as well...LOL
#33
Ok, "I want one for a C5." LOL shoot me a pm on pricing when you get a chance. thanks.
#34
I dont know yet because I have to make it first...
The C6 set up is $950 with all the idlers-belt and new AC compressor so it would be close, problem is I would need your balancer and jack shaft idler to machine the extra ribs into them.
Thats honestly why we do not promote this much because there's a lot of back and forth down time involved if the car is already together. If we are sending out a complete set up then it's no problem.
#35
#36
I install the 4040477 gaterback 4 rib belt and a new tensioner for the 4 rib and the results?? No belt slippage with AC on but when I go into boost the AC will be off. Thanks to everyone for the input.
#37
there is a new ecs fix for this..we experienced voltage drop with my car last monday at wot
Doug machines the jack drive for cog and cog the flip drive seperatly and all issues should diminish
Im working on mine right now
