really dumb question
Old Jul 14, 2013 | 06:27 PM
idontknow's Avatar
idontknow
Default really dumb question
i have the old GEN 1 A&A procharger bracket and i just ordered the NEW A&A procharger bracket, will my belt length be the same or will i need to play find a new belt size game.
Old Jul 14, 2013 | 07:54 PM
helga203's Avatar
helga203
Yes you will need to find a new lenght. Try to put your old one back on the new set up and gustimate your next size.
Old Jul 14, 2013 | 08:11 PM
joshtownsend's Avatar
joshtownsend
it should be about .5-1 inch longer
Old Jul 14, 2013 | 08:12 PM
4DRUSH's Avatar
4DRUSH
Post up your pulley sizes, may someone here has the same setup.
fillintheblanks's Avatar
fillintheblanks
belt games are not fun. good luck.
Old Jul 14, 2013 | 08:31 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
This has to be the dumbest question someone has ever posted.
No seriously though just contact Andy he should be able to help you.
Old Jul 15, 2013 | 03:50 AM
idontknow's Avatar
idontknow
I told you it was a really dumb question.
Right now its a D1 running. 3.9 pulley with stock crank pulley.
Old Jul 16, 2013 | 02:13 PM
Josh@AandASuperchargers's Avatar
Platinum Supporting Vendor
We have belt charts on the website for those that need guidance.
Scroll down on this page.
http://www.aacorvette.com/supercharg...e=instructions
Or look at this one, assuming you have a 6-rib setup and no kind of acc drive system.
I'd get both the 910 and 915 so you can get the best fit during the install. Those are Gates #'s listed so you can probably pick them up local and then return the one you don't use.
Old Jul 16, 2013 | 03:07 PM
chris308's Avatar
chris308
OP has the procharger bracket and head, still the same belts as Vortech setup?
Old Jul 16, 2013 | 03:50 PM
MVP'S ZO6's Avatar
MVP'S ZO6
I was just kidding it wasn't a dumb question.
Old Jul 16, 2013 | 03:55 PM
Yes they use the same belt size between Vortech or Procharger version.
Old Jul 16, 2013 | 04:28 PM
chris308's Avatar
chris308
Good to know, thanks!
Old Jul 16, 2013 | 07:40 PM
idontknow's Avatar
idontknow
Attachment 47729987
kick ***, thanks for the info. now i need to call procharger and get the longer dip stick
To really dumb question
