Getting antsy!
Old Aug 8, 2013 | 12:37 AM
FRiCK916's Avatar
FRiCK916
Default Getting antsy!
My car is at my shop getting some finishing touches put on it and a tune... so anxious to get some numbers. I was 467/438 with heads n cam before. Took those heads n cam off and put on cleaned up 317's cut for 10:1, V2si w/ 3.6", alky single nozzle meth, LXL 222/230 114+2 cam, 1 3/4" long tubes w/ off road X and OLSD tuned...
Whatcha guys think for numbers??
And on a side note, how would this cam fair against the ECS 346 cam??
Old Aug 8, 2013 | 01:10 AM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Should make some good power.
As for the ECS cam, I don't think you will pass smog with it. (Not sure if that's a concern for you or not)
Old Aug 8, 2013 | 01:16 AM
FRiCK916's Avatar
FRiCK916
At this point it isn't... I thought it would be, but honestly, a little extra money is worth not rearranging the car. I think down the line if someone could sell me on a ECS cam or something of the like I'll swap that in with some 243's again, maybe cut them down a little, run 80's and E85 and no meth.
My goal with this combo was 650. How far off am I?
Old Aug 8, 2013 | 03:39 AM
Y2KRoadster's Avatar
Y2KRoadster
Probably be at high 500's. I'll guess 570-590. If the heads are unported 317's, I'd think that would be hurting you a bit. Of course, if you go aggressive on the tune and spray a good shot of meth...then a 600 could be possible.
What is your exhaust setup?
Old Aug 8, 2013 | 06:40 AM
Robert 2000's Avatar
Robert 2000
Well I think you ll be close to 650. My car with A&A si trim on 3.6 pulley with 226/234 cam and meth made 605 rwhp with stock ls1 heads. With a good set of heads on the same setup you should make more than mine did. If it doesnt do 650 maybe try a 3.4.
Old Aug 8, 2013 | 07:07 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Thanks,Matt
Old Aug 8, 2013 | 11:45 AM
FRiCK916's Avatar
FRiCK916
You guys are killing me lol
Looks like I'm gonna put some 243's back on and a run a 8" crank... I just don't want any possibilities of slip with a 3.4" or should I even worry??
Old Aug 10, 2013 | 08:25 AM
Da_Whistler's Avatar
Da_Whistler
Those 317's should flow nicely with boost... I am running like heads on my forged stock cube setup/14psi with the ECS 1500 kit and Meth. Crappy LT's and gutted X pipe/cats. I made 645whp on a Mustang dyno. Those heads and my custom cam made a world of difference IMO
To Getting antsy!
