Disappointing performance results
Old Aug 31, 2013 | 01:29 AM
  #41
LedfootLarry's Avatar
LedfootLarry
Well Paul , when you made your runs , did you beat on your car ?
If you want to pull a good time , you have to drive the ever lovin sh*t
out of it !
Like the OP said , with your centri the powerband is exponential with rpm, what did you shift at ?
Not sayin there is nothing wrong with your car , just tryin to help .
Did you go through the traps in 5th gear ? Shifting to 5th can slow your top speed , its a hard gear to get sometimes.
I went through the traps @ 7300 rpm in 4th. I realize you can`t rev that high on a stock block, but these are considerations.
Next year try a higher diameter tire , maybe 1" higher, and that may let you stay in 4th.
Just some suggestions
Old Aug 31, 2013 | 12:02 PM
  #42
Roadking103's Avatar
Roadking103
Originally Posted by PRE-Z06
If someone is there to log your run, I'd check the IATs. Could be pulling a ton of timing after that long of a WOT pull at high rpms, power could be affected much differently than a short dyno run. Also what are you shifting at? The higher you shift a centrifugal the more average power it makes as they are the peakiest of FI setups being boosted based on engine speed, so the higher you spin it the more average power(ie faster) you'll be. Hope that helps, good luck next time!
Thanks great advice. Shifting just before hitting the rev limter.
Old Aug 31, 2013 | 12:07 PM
  #43
Roadking103
out of it !
Shifting just before hitting the rev limiter. Tried to stay in 4th but was about to hit the rev limiter just before the 1/2 mile mark. The cars times and speed are quicker but still pretty close to stock which is why I think something may need tweaking.
Larry your last run was Awesome!
Old Aug 31, 2013 | 12:30 PM
  #44
LedfootLarry
Thanks, but my last run was 2km slower, hit rev limiter and cog belt @ back of blower disintegrated
I drove home with no boost
all good now
Old Aug 31, 2013 | 12:32 PM
  #45
LedfootLarry
Oh, and tweaking is half the fun of all this !!
Old Aug 31, 2013 | 12:51 PM
  #46
Roadking103
all good now
Sh$t! To bad,I didn't know that. I guess I saw your 2nd run.
Old Aug 31, 2013 | 01:23 PM
  #47
RED99's Avatar
RED99
Defiantly need a boost gauge when running any kind of FI. I don't know why business's installing and selling kits wouldn't just make it part of the kit. Or at least suggest it to the customer as an add on. But it sounds like you are probably only making about 400 RWHP if you are hooking up good with those tires. Sounds like you have a boost problem. Have you checked for codes on the DIC?
FWIW! I ran 11.67 with my little maggie with only 450 RWHP with PS2 run flats and I had to roll into the throttle easy off the line until about 40-50 mph or I would just smoke the tires. With some sticky tires I know I could have got close to the 10's.
Old Sep 1, 2013 | 11:55 AM
  #48
Rob@ChampionMotors's Avatar
0Rob@ChampionMotors
Former Vendor
By our calculation in 4th gear, 3.42 rear gear, stock 26.1" tire at 6600 red line you would be going over 241+ kph before end of half mile.
Your blow off valve could be leaking.
Rob.
Old Sep 2, 2013 | 10:35 AM
  #49
Roadking103
Rob.
Hi Rob
I agree I should have hit 240 or better at the 1/2 mile mark. I'll look at the blow off valve and listen to see if I can tell if it's leaking. Thanks
Old Sep 2, 2013 | 11:53 AM
  #50
C5Natie's Avatar
C5Natie
OP, how much boost are you making?
Is it just me or is 592rwhp pretty high for a stock '03 Z06? I thought that Vortech kit made around 7-8psi?
Old Sep 2, 2013 | 12:03 PM
  #51
Chrisrokc's Avatar
Chrisrokc
Seems about right depending on the dyno.
Old Sep 2, 2013 | 02:24 PM
  #52
Roadking103
I'm not sure how much boost the car is making. I'm ordering a boost gauage. A&A tells me with the pulley I have it's about 8 or 9 PSI
Rob at Champion motors did the install. They posted the dyno chart and youtube video of the dyno pulls here on the forum. I'm told 592 rwhp is bit more than typical but the not the most they've seen from these kits.
Old Sep 2, 2013 | 02:35 PM
  #53
LedfootLarry
You know, there are so many variables with this, there might not be anything wrong with your setup.
Old Sep 2, 2013 | 04:04 PM
  #54
SBCGENII's Avatar
SBCGENII
I agree, lots of variables. The only reason I think something is wrong is he said it doesn't feel much different from stock.
Old Sep 2, 2013 | 05:18 PM
  #55
Roadking103
Yup lot's of variables, but there is no way the car is currently making 592 rwhp. I'm new to F.I so just learning but I'm not new to performance cars. I think the car should be a lot quicker.
I'm just learning about F.I. but I'm getting lot's of help and advice from the Corvette Forum. So I'm sure I'll get it sorted out.
Old Sep 2, 2013 | 05:25 PM
  #56
joshtownsend's Avatar
joshtownsend
if you really think there is an issue... start by making a boost leak tester.. cost about $15 and that will tell you if you have leaks anywhere.. then log boost, that will tell you if you have belt slip.. you need to get the mechanics figure out before you start chasing ghost that arnt there. These things are easy to do and will tell you alot.
Old Sep 2, 2013 | 07:00 PM
  #57
MotleyDrew's Avatar
MotleyDrew
I took a peak at the car and it looks and sounds fine. No visible belt slip, blow off doesn't seem to be sticking or leaking by sound when the you hear the car running at full tilt. We don't see these crazy times that others seem to be able to reproduce in other parts of the world in Ottawa. From my experience a stock Z06 in full street trim with just a blower and 9lbs of boost will usually trap 122 - 127mph on a C5. Add 20mph to that 1/4 mile mph and that would be a rough estimate for a 1/2mile speed. 145mph = 232km. To go anywhere near the 150mph in one of these cars you will need to be powershifting and leave like a mad man. I have a feeling Mr Roadking is probably just getting used to the power. Only thing I have suggested is to buy a flip drive and tighten the belt a little more.
I agree with LedFoot Larry and my Texas connection Boy Mr Blue that you also are not gonna have your best times on your inaugural 1/2 mile race. Lots of seat time and fine tuning can do wonders.
this is coming from someone who has had pretty much every issue you can with these cars over the years.
To Disappointing performance results
Old Sep 2, 2013 | 08:52 PM
  #58
Roadking103
I appreciate the help and suggestions. I'm new to F.I not modified cars or racing. Although different cars last summer I drove a buddy's supercharged camaro with similar power. You had to modulate the gas when shifting to 2nd or you would just spin the tires and go sideways. In my car the tries chripped and but bit . Grip aside you can feel a huge difference in the power. Bottom line I think the car was making boost but not anywhere near 8 or 9 PSI.
Old Sep 2, 2013 | 09:11 PM
  #59
MotleyDrew's Avatar
MotleyDrew
In 2003 I had a stock motor ls6 with a vortech s-trim at about 11lbs of boost. car made 503rwhp with blower , shorty headers and full exhaust. I could hook it in second. I never ran it at a 1/2 mile event but I would expect it would have ran very similar to yours. Get the boost gauge on it and come pick me up. I will watch it for you. We just need to find a place where we can bring it up to 6600rpm in 4th
Old Sep 2, 2013 | 09:15 PM
  #60
MotleyDrew's Avatar
MotleyDrew
Oh....don't ever drive a camaro again.
