Disappointing performance results
Old Aug 28, 2013 | 08:40 PM
Roadking103's Avatar
Roadking103
Default Disappointing performance results
This spring I had an A & A Corvette V3 si trim supercharger installed on my otherwise stock 03 Z06. Andy and Josh were great to deal with. Rob at Champions motors installed the kit and got an impressive 592 rwhp
Last year I did a ½ mile charity event. The event records your ¼ times and ½ mile speed. You get 3 passes. Last year bone stock best ¼ time 12.49 ½ mile speed 220 KMPH (137 miles per hour)
So with 592 rwhp I was expecting a significant improvement.
This year best ¼ mile 12.04 and 230 KMPH (143 miles per hour)
Same tires, similar weather conditions, same track and same driver. Somewhat soft launch and not power shifting this year and last.
My first thought was that the belt has stretched and is slipping. I don’t feel any hiccups, bucking or surging to suggest that the belt is slipping. The belt seems tight and appears to be tracking straight. I don’t hear any squeal or chirping from the belt and I don’t see dust from the belt or damage to the belt.
I’m disappointed in the performance results. The car doesn’t feel much faster than stock. I’m new to F.I and help suggestions would be appreciated.
Old Aug 28, 2013 | 08:49 PM
Darion's Avatar
Darion
Same tires huh, which ones might that be and what size? I have PS2's that were great on stock motor but are not up to the task with 600whp.
PC
Old Aug 28, 2013 | 09:04 PM
Roadking103
PC
Thanks for the reply. Continental Extreme Contact tires. New last year. Very little wheel spin, tires seemed to hook
Old Aug 28, 2013 | 09:22 PM
4DRUSH's Avatar
4DRUSH
From what I read, you gotta buy a bunch of upgrades for that A&A kit to go fast, you do that yet?
Old Aug 28, 2013 | 09:24 PM
SBCGENII's Avatar
SBCGENII
Good news, there is something wrong with your car. It should feel much faster then stock. I would call champions and let them know what is going and bring the car in for them to check out. Could be a few things holding you back belt slip, boost leaks, clogged cats etc. Do you have a boost gauge?
Old Aug 28, 2013 | 09:35 PM
Roadking103
Great points, thanks! Unfortunately Champion motors is a 4 ½ drive one way. So I’m going to try and sort it out on my own first. But if I can’t sort it out Champion definitely can.
I wondered about a boost leak but wasn’t sure how to check that? I don’t have a boost gauge but plan to order one right away. Any recommendations on which gauge? Digital or mechanical? Interesting point on the clogged cats. I’ll look into that too.
Old Aug 28, 2013 | 09:53 PM
SBCGENII's Avatar
SBCGENII
Mechanical. You could probably find one at the autoparts store. How close to dasilva motorsports are you?
Old Aug 28, 2013 | 10:02 PM
SBCGENII's Avatar
SBCGENII
http://www.jegs.com/i/JEGS/555/41224...FVNo7AodVWQASQ $30 from jegs. You might be able to find one at the autoparts store too. I am recommending these for troubleshooting, might not match well in a c5. They make so really nice ones that let you know your peak boost. That way you wouldn't have to watch the gauge on your pull. If you have any logging software you could use that as well.
Old Aug 28, 2013 | 10:07 PM
Y2KRoadster's Avatar
Y2KRoadster
I got my boost/vac gauge at Orielly Auto Parts. It was about $65 IIRC and works great. You definitely want a mechanical. I'd get that and make sure you are running the correct amount of boost.
What are your a/f readings at WOT?
Old Aug 29, 2013 | 12:52 AM
turbo-civic-si's Avatar
turbo-civic-si
LOL wait really?
Old Aug 29, 2013 | 01:32 AM
Y2KRoadster
Originally Posted by turbo-civic-si
LOL wait really?
Yep...Autometer vac/boost gauge. Mechanical is more accurate. Sorry if you spent 200 on an electrical that doesn't read as well.
Old Aug 29, 2013 | 10:09 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Was your car dyno tuned, track tuned or both?
4DRush ran 8's on his first pass, never changed a belt or motor and never ran anything less. Everyone else had to work for it.
ECS has enough experience to know the difference between a short pull on the dyno and a full 1/4 mile pull. Those differences in the tuning are what is keeping you from greater gains at the track if I had to guess.
Old Aug 29, 2013 | 12:21 PM
turbo-civic-si
Please explain to me how gauge accuracy has anything to do with being Mechanical or Electronic.
Old Aug 29, 2013 | 12:34 PM
Milan's Avatar
Milan
Lol you have obviously never lived at elevation. Go take your electronic boost gauge to Denver and compare it to a mechanical one and you will see how worthless electronic gauges are.
Old Aug 29, 2013 | 01:13 PM
turbo-civic-si
I'm not going to argue with you because this is way off topic and you are too dumb to understand.
Old Aug 29, 2013 | 01:20 PM
joshtownsend's Avatar
joshtownsend
The mechanical one reads so my better because its not in some junkie civic...that i do understand..
If your gonna drive an import.. at least have some class...
Old Aug 29, 2013 | 01:23 PM
joshtownsend
OP, boost gauge will tel you everything you need to know... You did pick up 6 mph on the back half and 1/2 sec in the quarter.. more power is one thing but driving it is another.. if this is the only time you do a race like this, improvements whatever they are , is always a good thing.
To Disappointing performance results
Old Aug 29, 2013 | 01:24 PM
SBCGENII's Avatar
SBCGENII
This place has been extremely entertaining as of late.
Old Aug 29, 2013 | 01:30 PM
Chrisrokc's Avatar
Chrisrokc
I am having a similar issue but it is not due to boost or anything. Power is there but getting it to the ground is the problem. You can see this if you compare time slips. Look for massive gains past the 1000 foot mark.
Old Aug 29, 2013 | 01:43 PM
stevensa's Avatar
stevensa
Electrical gauges have an atmospheric reference, just like a mechanical gauge. Electrical gauges use the same type of sensor design that OEM Map sensors use. If they were worthless every car in Denver would run improperly.
