fuel system
Sep 15, 2013 | 09:51 AM
fuel system
For those that have run it, is there any issues with the stock fuel rails (specifically the better 98 system with return) supplying 750-800rwhp?
Sep 15, 2013 | 12:30 PM
Quote:
Originally Posted by
Blow Torch
in that power level and a good regulator you are max
Sep 15, 2013 | 12:41 PM
I know everyone says it, but I think I can be satisfied in the 800rwhp range if I can get there. I am at 700 now and it is a little hard to handle at times.
I do know I don't want to have to update all of the fuel system....
Sep 15, 2013 | 01:01 PM
Most guys go to ls2/3 rails when going over 7/800. ECS states on their website that upgrading to LS2 rails is recommended with their fuel system.
Sep 15, 2013 | 05:31 PM
I have read in the past that the early (98 style) systems with the return lines were capable of a little more hp than the later style, but have no personal experience with it.
Sep 15, 2013 | 06:43 PM
Stock rails are more then fine..
Sep 15, 2013 | 07:09 PM
Thanks Josh
Are you running stock???
Sep 15, 2013 | 11:04 PM
Your stock rails are fine... having returnless vs. return style fuel system is a more deciding factor than what rails you're running.
I think aftermarket rails are more for having more and easier plumbing connections than they are for flow...
An interesting read:
http://kennebell.net/KBWebsite/Commo...rFuelRails.pdf
