BOVs in different locations?
Old Nov 9, 2013 | 02:53 AM
Mattie Num Nums's Avatar
Mattie Num Nums
Default BOVs in different locations?
I have a question. I noticed some of you have the BOV in front of the TB instead of in the wheel well. Any particular reason why?
Old Nov 9, 2013 | 04:01 AM
ajrothm's Avatar
ajrothm
You really want the BOV before the intercooler so in normal driving, you are not pumping hot air into the intercooler and heat soaking it. The venting response time is better when the BOV is as close to the blower as possible. (Ie. chopping the throttle while in full boost, less hit on the compressor/belt). Plus it can help with the noise having the BOV down below the car.
Most people that mount them on the charge tube before the TB do it for easy fitment and more often then not, "poser points".
Old Nov 9, 2013 | 04:47 AM
Mattie Num Nums
So the best place to keep it, is in the wheel well? (I don't mind it there at all.)
Old Nov 9, 2013 | 09:18 AM
StealthFRC's Avatar
StealthFRC
Im sure your refering to my pic i posted... My car has 2. One in the original location and one in front if the TB
Old Nov 9, 2013 | 10:20 AM
joshtownsend's Avatar
joshtownsend
the best place it right after the volute.. but its hard to get it there..
Old Nov 9, 2013 | 01:17 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Mine now mounts to the intercooler itself. See to the right of the pic at the bottom of the intercooler
Old Nov 9, 2013 | 01:32 PM
CorvetteCoop's Avatar
CorvetteCoop
Mine is also setup like this. I have the original one that comes with the kit in the original location (on the pipe that runs from the supercharger to the intercooler) and then a Tial 50 mm near the throttle body. I believe the only reason why this was done by the previous owner was to scare small children with the BOV sound.
Old Nov 9, 2013 | 02:57 PM
StealthFRC's Avatar
StealthFRC
Mine has 2 tials. Running it like this actually quieted down the car 500%
Old Nov 10, 2013 | 09:31 PM
4DRUSH's Avatar
4DRUSH
Originally Posted by Johnny08
I now have only one Tial and need to add a second one. The one I have is at the end of the ECS cooler like they set it up. What's the best place to install the second one? At the end of the cooler, next to the first one (on top of it)? Into the pipe between the blower and the cooler? Or into the intake pipe? Would like to hear your thoughts on this, thanks!
Between the blower & innercooler is best.
Install 1/4 vacuum lines from different sources.
To BOVs in different locations?
