The "TUNE" must be adjusted to the new gearset in the PCM - it will be listed and calibrated for the current 3.73 and it will need to be now set for the 3.15's!
It's a simple easy input of numbers in the correct table and all will be good!
Use HP Tuners and within 5 minutes it will be complete!
Yes it will need calibrated before it is driven. The speedometer will not be effected as it reads off the ring gear. The shift points will be off and MOST importantly.... The torque converter will not lock properly and will/could cause the transmission to overheat.
You don't have to, but you should, and even the engine could probably handle a good deal more timing as is now sees less load.
Thanks! Makes sense. Definitely revs like a 2 cycle now and I saw some noticeable uncharacteristic smoke at top of wot! I don't think the tune is optimized now. Sorry to OP for hijack!
at the present time? 3.73 last year at this time it was a 3.42 but i was told by mayhem i must be drunk!!!! so then how did it have a 3.42 rear tuned in it for 3 years??? i am calling ummmmm
