Treadstone Intercooler, experience anyone?
Old Nov 20, 2013 | 12:43 AM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Indeed!!
Old Nov 20, 2013 | 09:07 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Big intercooler, small out let, no thanks.
Old Nov 20, 2013 | 10:18 AM
MVP'S ZO6's Avatar
MVP'S ZO6
Good catch. It is small isn't it. At least it looks small.
at least the intercooler dont have to do the rope a dope.
Old Nov 20, 2013 | 10:52 AM
JDS99's Avatar
JDS99
Originally Posted by MVP'S ZO6
Anyone have specs and dimensions on the big TS intercooler that y'all use in these cars?
Specs and dimensions are on their website....
TRTTC9:
Core Size, 25" X 9" X 3.5"
1-3" outlet and 2-2.5" inlets
Outlet is angled 15 degrees
1950 CFM flow rate
1300 HP efficient
2psi pressure drop at 1950cfm
Sounds to me like everyone that has actually used/is using them are happy with them.
If you don't want the 3" outlet, then someone can order just the core or modify it. Guess I would then ask what is the actual flow area through the throttle body on the car?
The only one that has had a negative report in here for these is ECS, who has their own product offering...
Old Nov 20, 2013 | 11:38 AM
SBCGENII's Avatar
SBCGENII
How much power can you pick upgrading from a 3'' to 4'' pipe to the throttle body on a car running a novi 1500/2000?
Originally Posted by 69ls6
love mine..1k rwp 347 ysi
BS the outlet is to small.
Old Nov 20, 2013 | 11:39 AM
SBCGENII's Avatar
SBCGENII
Originally Posted by SBCGENII
Pressure loss? Didn't lower IAT's? Or ugly welds?
Old Nov 20, 2013 | 12:16 PM
DOUG @ ECS's Avatar
DOUG @ ECS
I do not have direct numbers sorry, but there is a power difference, for instance back in the 90's an upgrade to the Paxton Mustang kit was a larger duct and it would pick up power directly from the swap. More so then the ducting though is the outlet diameter creating a bottle neck.
ok, that was funny. Obviously Ricky's car gets it done! I'm a nit picker, thats my job, winning is often done by fractions. Good is good, better is better.
The intercooler we received was simply not the quality that we would install in a car, I didn't go any farther with it.
Old Nov 20, 2013 | 01:41 PM
SBCGENII's Avatar
SBCGENII
Understood.
Old Nov 20, 2013 | 03:11 PM
Shoaf85's Avatar
Shoaf85
I will be running the treadstone intercooler on my car. My brother owns an "Import" shop and he ran this intercooler (TTRC9) on his 1000hp 2.0L Acura Integra with great results. His car was running 40+ psi with a precision 72mm turbo and saw hardly any boost drop and the IAT's were controlled very well acutally dropping 20+* from start of 1/4 mile to finish (I've seen the logs), car ran 8.8's@174. Although placement was directly in the front bumper which will see better aiflow than most us C5 owners will see, however after seeing these results I am sold on it especially for the price.
Old Nov 20, 2013 | 10:01 PM
directnosfogger's Avatar
directnosfogger
you know the reason i was hesitant to pick up one initially was because the pic in the web ad looked awfully small for the dimensions it listed. now that i have actually seen a life size photo of the intercooler, it looks absolutely perfect.
doug - i value your opinion and you say this is terrible build quality. am i to expect longer years of service out of an ecs intercooler vs this one? i'm having a hard time understanding the quality of this because i've seen some really crappy intercoolers before from ebay, but even those worked as expected.
both inlet and outlet are 3 inches. this is more than enough for my needs and anyone making less than 4 digit power. how much larger do you want the piping anyway?? does anyone have any research numbers of how much more air charge is capable of being compressed between 3, 3.5, and 4 inch piping? i can't imagine seeing much benefit in 4 inch charge piping if i don't have a 102 mm intake and tb. likewise - i would need a 92mm intake and tb for 3.5 inch piping. and then we get into the conversation of lag..could i even make the determination that i would spool up a split second faster with smaller piping? remember the whole point to redoing my intercooler setup is to be more efficient..
what is everyone's thoughts on running piping around drivers side or passenger side from passenger side mounted head unit?
Old Dec 17, 2013 | 09:22 PM
95wht6spd's Avatar
95wht6spd
Did you buy one?
Old Dec 17, 2013 | 10:02 PM
69ls6's Avatar
69ls6
My is 3" in 3" out and I mph 158mph on a bad pass in a stick.Yes 1k rwhp.This is the only cooler that has ever been on my car.
Old Dec 17, 2013 | 10:10 PM
  #33
turbo-civic-si's Avatar
turbo-civic-si
They are good intercoolers.
Old Jan 6, 2014 | 11:32 PM
  #34
speedyhawk101's Avatar
speedyhawk101
I have this intercooler. Seems to get the job done. 16psi from a V2 on a 383. Not sure what the power is just yet. 3" on both ends. I'd buy it again if I build another car.
Old Jan 7, 2014 | 12:10 AM
  #35
a/c man's Avatar
a/c man
how does it compair in size to others like the A&A or ecs
Old Jan 7, 2014 | 02:42 AM
  #36
fotoboy's Avatar
fotoboy
I have the smaller brother to this that's rated to 968 whp. Happy with mine at 817 whp. Thinking I need to go bigger if I add anymore hp though.
Old Jan 7, 2014 | 10:17 AM
  #37
robert miller's Avatar
robert miller
Default ttt
ECS here I went with the biggest one that Doug has and you can't put a bigger one in the c5. Very nice but just will not cut the inner frame rails to go bigger. ECS all the way here..Robert
To Treadstone Intercooler, experience anyone?
Old Jan 7, 2014 | 12:30 PM
  #38
long's Avatar
long
I thought the outlet was too small also. I chopped it off and welded on a 3.75". Works great for me.
Old Jan 8, 2014 | 05:58 AM
  #39
narfdanarf's Avatar
narfdanarf
We are using a treadstone style core with custom endtanks on my car. I am confident it will be able to handle anything the 80mm can dish out.
Old Jan 8, 2014 | 10:08 AM
  #40
vrybad's Avatar
vrybad
That's the way to do it!
Nice job!
