Ported LS2 vs LS6
Old Jan 15, 2014 | 01:19 PM
FRiCK916's Avatar
FRiCK916
Default Ported LS2 vs LS6
Im currently at 646/585 with 10.2lbs at 6700rpm, limiter set at 6800... cam is a 222/230 114+2.. With a stock ls6 and 75mm throttle body... would a ported LS2 manifold and 90mm pick me up anything/be worth my time?
Old Jan 15, 2014 | 01:23 PM
robert miller's Avatar
robert miller
Arun, ran the 75mm TB for the longest time befor going to the ls2 90mm TB. His car did great on the smaller. But you can pick one up at almost nothing. Robert
Old Jan 15, 2014 | 02:03 PM
Milan's Avatar
Milan
Ported LS2 is better. The ls2 is actually a better intake, but the manufacturing process used made it not flow as well. Once ported it's no contest.
Old Jan 15, 2014 | 02:31 PM
FRiCK916's Avatar
FRiCK916
Ok good deal... so is that a bolt on deal? I know I'll need the 90tb and the caspers harness... but will the ls1/6 rails bolt on with my 60's? And if ya'll had to guess what would I be gaining?
Old Jan 15, 2014 | 03:10 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Old Jan 15, 2014 | 04:43 PM
FRiCK916's Avatar
FRiCK916
Ehh.. After research, seems as if I should just do a FAST if anything. Wasn't aware ide need rails, new o rings, spacers... blah!
Old Jan 15, 2014 | 04:52 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Do you have aftermarket rails already? If so its as easy as some new brackets.
New o rings and spacers for what?
Old Jan 15, 2014 | 05:37 PM
FRiCK916's Avatar
FRiCK916
Im still on stock rails... on some posts I was reading something about bigger o rings for the injectors, and spacers for the rails?? I dunno lol im slightly confused on it... it just sounded like a lot for a little is all.
Old Jan 15, 2014 | 07:03 PM
Milan's Avatar
Milan
Must not have been that thorough on your research. The FAST is setup for an LS2 so you will need new rails for that too.
Old Jan 15, 2014 | 07:07 PM
FRiCK916's Avatar
FRiCK916
Just took a FAST off of my car when I put the blower on.... bolted together without issue. If you're talking about a 102, then you're correct. I had a Vengeance 92.
Old Jan 15, 2014 | 07:27 PM
Milan's Avatar
Milan
The 102 is the only one worth having. Anything older will leak with boost. Some people have problems with the 102 even, although FAST claims it's tested to 61 psi
Old Jan 15, 2014 | 07:28 PM
MX621's Avatar
MX621
just not worth it.. ls6 manifolds have made over 900 on FI. ive also seen reputable ported ls2 manifolds dyno only 3-5 hp over a 75mm/stock ls6 manifold. this has been beat to absolute death on ls1 tech
Old Jan 15, 2014 | 07:41 PM
FRiCK916's Avatar
FRiCK916
Originally Posted by mx621
just not worth it.. Ls6 manifolds have made over 900 on fi. Ive also seen reputable ported ls2 manifolds dyno only 3-5 hp over a 75mm/stock ls6 manifold. This has been beat to absolute death on ls1 tech
thanks!
Old Jan 15, 2014 | 07:46 PM
robert miller
thanks!
I had a ported ls2 intake on one of my old set up's that worked great. Robert
Old Jan 16, 2014 | 04:24 AM
inspector12's Avatar
inspector12
Its FI! Hard to beat an LS6 intake. By far the strongest factory intake manifold, they were expensive to manufacture. Thats why GM tried the LS2. Looking for gains and there were some N/A but not much. Most were do to the larger TB and the gains were up top not though out the power band. But you will see minimal gains from an intake swap alone. and Price per HP, your better off putting a smaller pulley on there if you can etc... GL!
Old Jan 23, 2014 | 11:44 PM
Mike94ZLT1's Avatar
Mike94ZLT1
I've never seen someone gain power by switching from an LS6 to an LS2 intake on a naturally aspirated motor. TB aside, the LS6 intake is a superior design.
Old Jan 24, 2014 | 12:19 AM
fotoboy's Avatar
fotoboy
I've seen 2 102 fast and one 92 fast come apart from as little as 11 lbs.
To Ported LS2 vs LS6
Old Jan 24, 2014 | 12:30 AM
MVP'S ZO6's Avatar
MVP'S ZO6
the new ones are supposed to be cured from that. not sure as to that being fact though. just rumor.
Old Jan 24, 2014 | 12:34 AM
MVP'S ZO6's Avatar
MVP'S ZO6
you probably wont on a NA engine but you port a LS2 and they seem to flow better than same ported LS6. Actually had numbers to back this up back in the day but I lost em. the 90 mm opening of the LS2 does have an effect on capability!! vs the 76mm opening of the LS6.
Old Jan 24, 2014 | 12:49 AM
a/c man's Avatar
a/c man
Your just saying that because you have one hahaha...
