ev1 injector question
Old Feb 14, 2014 | 01:47 PM
seansz28's Avatar
seansz28
Default ev1 injector question
Are all ev1 style injectors interchangable?
Old Feb 14, 2014 | 02:24 PM
regorih's Avatar
regorih
yes. EV1 is just the style of connector on the injector.
Keep in mind that they come in different lengths, some short others tall.
ROger
Old Feb 14, 2014 | 07:23 PM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
ROger
NO! They're not.
You need to make sure they're high impedance injectors.
If you don't know, put a meter across the pins and check. Should read higher than 10 ohms or so to be considered high impedance. Most read 14 ohms of I recall correctly.
The low impedance injectors require a driver and by the time it's all said and done, you'll wish you just bought a set of high impedance.
Old Feb 14, 2014 | 08:43 PM
a/c man's Avatar
a/c man
Originally Posted by BLOWNBLUEZ06@RKT56
NO! They're not.
Good to here it from Brett
To ev1 injector question
