SD tune
Old Feb 18, 2014 | 10:58 AM
ysb02's Avatar
ysb02
Originally Posted by PEETYZ
Maybe I am wrong here but if you are going to use the MAF don't you tune the car in SD then turn on the maf and further tune?
Yes for most ECUs if the tuner is doing it right. That's why a SD tune should be easier than a MAF.
lol @ the guy that said SD tunes are only done WOT.
Old Feb 18, 2014 | 02:45 PM
1slowride's Avatar
1slowride
Default Sd
I went SD just 2 days ago, but still in the process of tuning it. I have no impressions just yet other than seems the car is a little more responsive and smoother at light driving and cruise. We still have to tune it at WOT,,,,,,,,,,,,,,. We had a good problem that made us quit for the evening, it would not hold traction even at highway speeds on full boost.
Old Feb 18, 2014 | 02:56 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Speed density is essentially mechanical tuning. F.I. with out getting into too much detail as to why the MAF dont work, guys in the LSx world use it because the MAF sensor don't work.
What people forget is that even in stock form these cars run a combination of speed density and MAF. In fact in a stock corvette for example when you go WOT (throttle transient), your MAF sensor isn't even being used for fueling calcs and neither is your narrow band front o2 sensors. They just don't have the resolution or response time to do so. In this case your car relies completely on the VE and PE tables until you "simma down" or go back to part throttle cruising. A Good MAF Tuned car will be just as smooth ad a good SD tuned car and visa versa.
Old Feb 18, 2014 | 03:12 PM
PEETYZ's Avatar
PEETYZ
Yep now for more "tame" setups a maf could actually help smooth things out in driveability etc correct?
Old Feb 18, 2014 | 03:41 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Yes. With out getting too heavy into it, the MAF It's just kind of for auto correcting type of thing and for steady steady state type of environment but the computer still relies on the VE for throttle transients. To answer your question a good tuned VE table is just as important and you won't notice a difference in smoothness from a MAF/VE setup to just a VE (SD) setup so as long as the calibration is correct.
This is why when tuning a MAF setup if you do a head and cam swap and your tuner says he don't dial in the VE and only the MAF, get in your car and drive away.
Old Feb 18, 2014 | 04:11 PM
PEETYZ's Avatar
PEETYZ
Thank you sir! I know my tuner(Mike at Proxses Tuning which is small shop in Dayton, Ohio ) is highly recommended in my area and will explain exactly what he is doing and why he is doing it. Most of the stuff is way over my head but very interesting.
Old Feb 18, 2014 | 04:14 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Good deal man!!!
Ps if im wrong on any of this stuff, blownbluezo6 taught me.
I kid I kid!!!
Old Feb 18, 2014 | 04:40 PM
Rx7Rob's Avatar
Rx7Rob
Originally Posted by veneno
yeah I can't pass Maryland emissions if there is an error code stored
CRAPOLA! I had my car tuned last year and went SD at the recommendation of the turner. We did discuss an OBDII emissions check.
I'm up for an emissions check later this year so I guess I'll find out. Not going to be happy if it fails.
Old Feb 18, 2014 | 04:46 PM
MVP'S ZO6's Avatar
MVP'S ZO6
You can turn MIL lights off set to no error reported Ect. Not sure if they can tell.
Old Feb 20, 2014 | 07:35 PM
LedfootLarry's Avatar
LedfootLarry
[QUOTE=PEETYZ;1586201621]
I have a newer LS 3/7 etc credit card style in my car
Then your tuner can charge for your tune instantly
just kidding, lots of good info guys
Old Feb 21, 2014 | 09:22 AM
PEETYZ's Avatar
PEETYZ
[QUOTE=LedfootLarry;1586223301]
Yea it has he "pay wave" feature so as soon as it shows up at the shop it gets scanned and charged...
