SD tune
Old Feb 17, 2014 | 12:55 PM
LedfootLarry's Avatar
LedfootLarry
Default SD tune
With an SD tune, can you make boost changes without retuning ?
Old Feb 17, 2014 | 12:58 PM
dsmlights's Avatar
dsmlights
yes if you have previously tuned that boost already.
Old Feb 17, 2014 | 04:25 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
No.
Old Feb 17, 2014 | 04:45 PM
LedfootLarry
Originally Posted by MVP'S ZO6
No.
thanks, I think the OP did not understand, I should have stated "change pulley size"
Old Feb 17, 2014 | 06:37 PM
PhysicsDude55's Avatar
PhysicsDude55
If you are going to MORE boost, then you'll need to retune.
Old Feb 17, 2014 | 06:45 PM
LedfootLarry
But if I want to "pulley up" , go larger, no retune needed ?
Old Feb 17, 2014 | 06:50 PM
sami85L98's Avatar
sami85L98
than you need FINE tuning.....lol.
Old Feb 17, 2014 | 07:02 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Assuming your tune is optimal based on your current pulley size, your going to need to retune the car whether you go with a smaller or larger pulley from what ever you currently have. I.e. if you have a 3.0 pulley and you change to a 2.85 pulley but make no changes to the tune, the car is going to run leaner (in boost) if you do the aforementioned but go from a 3.0 pulley to lets say a 3.3 pulley the car is going to run richer.
Call it what you want fine tuning re tuning Ect. It still needs to get done either way if you want to keep the same AFR.
Old Feb 17, 2014 | 10:00 PM
Milan's Avatar
Milan
The answer is maybe. 50% on luck and 50% your tuner's skill
Old Feb 17, 2014 | 10:57 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Old Feb 18, 2014 | 01:59 AM
auctiondepot's Avatar
auctiondepot
Ive never been a fan of speed density tuning for a street car.
it is an approximate tune base on a specific ambient condition.
it takes manifold pressure and rpm to estimate fueling and ignores temperature and humidity at operating temperature. If you don't have a 2 bar map for boost you lose the known pressure also.
further SD tuning is done at WOT which is specific for racing not the street. it is easy to control the fueling at a unique set of conditions.
A good MAF tuning requires a competent tuner and a lot of work. what we need is a fuel pressure system that is set at the rail not at the fuel tank and this makes SD even more variable.
but then again I could be wrong.
Old Feb 18, 2014 | 06:50 AM
Chris Stewart's Avatar
Chris Stewart
After getting SD tuned for say 25psi, I can run any boost up to 25 and the AFR is always right. When MAF tuned, my MAF was maxed out about 550hp, then fueling was tied to the wideband/RPM and not able to correct itself for different boost.
Old Feb 18, 2014 | 06:51 AM
danieloneil01's Avatar
danieloneil01
Oh boy
Temperature is needed for idle, part and WOT for any scenario. SD is much harder over MAF to fine tune.
Old Feb 18, 2014 | 08:53 AM
1slowride's Avatar
1slowride
Default Restrictor plate
I have the same original question, with 1 exception.
Would you need to re-tune if you DID NOT change the pulleys, but did open up the Restriction plate?
Old Feb 18, 2014 | 09:06 AM
Blow Torch's Avatar
Blow Torch
Opening up the restrictor plate would allow more boost, so yes.
Old Feb 18, 2014 | 09:19 AM
PEETYZ's Avatar
PEETYZ
I would have the tune atleast checked if changing boost....
Maybe I am wrong here but if you are going to use the MAF don't you tune the car in SD then turn on the maf and further tune?
I agree with the factory LS1 and LS6 Maf being done around 550. I have a newer LS 3/7 etc credit card style in my car because of this and am fine at 600 wheel. I can see maxing that out later down the road with 700+ wheel maybe? The factory ZR1 uses a Maf doesnt it? What are it's limits?
Old Feb 18, 2014 | 09:59 AM
veneno's Avatar
veneno
I went ahead and purchased an LPE 100mm maf my vette is a 98 model
so it has a smaller 75mm maf and the 2001-up have the bigger 85mm
The c6 and up vettes are easier to tune with larger mafs something to do with more flexibility in the pcms. If you are going SD ditch the maf and replace your map with either a 2bar or 3bar map. Im holding off on SD from what I have read an error code is stored in the pcm and it won't pass emissions
To SD tune
Old Feb 18, 2014 | 10:10 AM
Chris Stewart
Yes it will pass emissions here with the 0103 error code. They allow one code and it doesn't trigger a check engine light.
Old Feb 18, 2014 | 10:13 AM
helga203's Avatar
helga203
Mine passed emissons in IL, Where they check PCM or check engine light? It's tuned out to not throw a code.
Old Feb 18, 2014 | 10:31 AM
veneno's Avatar
veneno
yeah I can't pass Maryland emissions if there is an error code stored
