3 Bar Map.
Old Mar 19, 2014 | 05:22 PM
Corvette0096's Avatar
Corvette0096
Default 3 Bar Map.
Anyone try these?
http://www.efisource.com/shop/ls1-st...ar-map-sensor/
Old Mar 19, 2014 | 06:12 PM
Slow Z06's Avatar
Slow Z06
Very interesting
Old Mar 19, 2014 | 06:23 PM
Corvette0096
[QUOTE=Slow Z06;1586446629]Very interesting
I have one on the way.
Old Mar 19, 2014 | 08:23 PM
Chris Stewart's Avatar
Chris Stewart
I remember this old thread, with some reputable tuners discussing cheap MAP sensors, that were not happy with them. Hopefully it works for you.
http://forums.corvetteforum.com/c5-f...r-28-80-a.html
Old Mar 19, 2014 | 08:45 PM
Corvette0096
I will find out more in a few days.. Like a marriage, roll the dices.
Old Mar 19, 2014 | 10:31 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
You loose some resolution going to a 3 bar. Most around here can get away with a 2 or 2.5 bar sensor.
Old Mar 20, 2014 | 02:44 PM
kromberg's Avatar
kromberg
Yes you loose some lower pressure resolution, but gain a lot of high pressure resolution. If you are going 3-bar, you will need that high pressure resolution
Old Mar 21, 2014 | 01:26 AM
RonSSNova's Avatar
RonSSNova
[QUOTE=Corvette0096;1586446717]
Originally Posted by Slow Z06
Very interesting
It will be all my fault......
Old Mar 26, 2014 | 10:03 AM
Julio's Avatar
Julio
MAP sensors are the one item I deal with a lot. They are like the most reliable sensors on the planet. The failures I have seen over the last 10 years are from cheaper Chinese knock-off versions.
It really depends what your using it for. Example.. if your using it to hook up an electric boost gauge then it doesn't matter if it fails.
Use it for your meth kit or engine management.. you'll wish you never went there sooner or latter.
HTH
Old Mar 27, 2014 | 04:18 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
my .02 was in the other thread and it still stands and I'll add that later I accidentally ended up with another 3 bar sensor from China. While it wasn't DOA, I wish it had been because it failed after 3 weeks. Had I not had my laptop and gotten creative by using my Alky Control 2-bar for a MAP signal and flashed the tune to a 2-bar to get me home, I would have been paying a ridiculously high tow bill. Especially being 100 miles from home.
Good luck! I have a feeling you might need it.
Old Mar 27, 2014 | 08:51 AM
robert miller's Avatar
robert miller
It is just crazy a person put this much money into a build, Then do stuff like this to his car with cheap azz parts that have failed time after time.
Old Mar 27, 2014 | 09:54 AM
Corvette0096
[QUOTE=RonSSNova;1586457987]
Ron, I trusted you on this....
Old Mar 27, 2014 | 07:03 PM
Chris Stewart
Impressed with that story Brett, scrounging the alky MAP for a field repair.
Old Mar 27, 2014 | 11:44 PM
Corvette0096
Map sensor has this on it.
pbt-gf30
Old Mar 28, 2014 | 03:49 PM
Yasei's Avatar
Yasei
pbt-gf30
That's the designation for the (black plastic) material from which the sensor housing is cast of.
Old Mar 29, 2014 | 07:00 PM
RonSSNova's Avatar
RonSSNova
Well, buy one from Dsteck then.
Send that one back with an explanation.
I made my own, so if it busts it will truly be my fault.
To 3 Bar Map.
