Tire size HELP
Old Mar 24, 2014 | 09:55 PM
evillsx's Avatar
evillsx
Default Tire size HELP
Will a 305-40-18 fit under a stock height 98 c5?
Thanks for any help!
Old Mar 24, 2014 | 10:32 PM
junk c5's Avatar
junk c5
I've got a 305-35-18 on my c5. Idk how to post pics, but if you like I'll text u a couple pics of how it sits.
Old Mar 24, 2014 | 10:54 PM
robert miller's Avatar
robert miller
Man with the correct off set on a rim a 345 will just stick out a hair on the car. Plus without being tubbed. The clown in here has a 345 on his car with a aftermarket rim.
Old Mar 25, 2014 | 02:48 PM
evillsx's Avatar
evillsx
Thanks guys any actually running one or tried? I'm running 35s now bought a set of 40s drag radial hoping they will fit.
Old Mar 25, 2014 | 03:31 PM
robert miller
You will be good Crap I am running a 50s drag radial 28 inch tall on the rear.
Old Mar 25, 2014 | 03:49 PM
evillsx's Avatar
evillsx
Awesome thanks robert thats what i wanted to hear!
Old Mar 25, 2014 | 07:14 PM
PhysicsDude55's Avatar
PhysicsDude55
There's plenty of talk about 28" tires fitting in C5's, except they usually rub the brake duct if you have them (Z06) and will tend to rub the inner fender well a little bit depending on your wheel offset and suspension.
305/40/18 comes in at ~27.7", so just a tad under 28", so I don't think you should have any issues.
Hell, I just bought a rear set of 305/35/18 tires, now you're making me wish I had bought some 305/40/18s!
Old Mar 25, 2014 | 09:00 PM
a/c man's Avatar
a/c man
they will fit if its a z06 you will need to remove the rear ducts
Old Mar 25, 2014 | 09:16 PM
mcshocks's Avatar
mcshocks
I run a 28" tall 275 on mine, had to ditch my Z06 brake ducts and they rub the fender liners. I clearanced the liners but I think I'm ditching them this year, they scrub still every once in a blue moon on a hard launch.
Old Mar 25, 2014 | 09:50 PM
Milan's Avatar
Milan
My 17" ET streets are actually 27.2 and they still rub the liner (but not the brake ducts)
Old Mar 26, 2014 | 10:12 AM
robert miller
Default ttt
To the OP here. If you go with a c6 cradle under a c5 body it will bolt right up no problems. But what that does with the c6 cradle under it is MOVES the rear tire back 5/8 of a inch. This will let you clear a 28 inch tall tire in the front and it will not rub anything at all. But if you go with this set up with a auto trans you have to also buy a 5/8 plate from RPM with is 500.00 to marry up the trans to the rear end.
If you go with the t6060 you don't need that. But you will need a lot of money to replace the clutches in the car if you are really hard on it.
Again RPM transmissions is the only way to go in my book here. Todd & Rodney will stand behind all of their stuff plus help a custom out in ever way possible. Robert
To Tire size HELP
