Drive shaft couplers - stock, poly or ?
Old 04-11-2014, 09:48 AM
Patches
Support Corvetteforum!
Patches's Avatar
Made by DSS and sold by RPM and others:
http://rpmtransmissions.com/newproducts.html
http://www.c5racer.com/catalog/c5-c6...FYtDMgod-BEA6A
http://www.floridaspeedandpower.com/...5-c6-corvette/
Here's a thread on both the DSS and Prothane versions:
http://forums.corvetteforum.com/c5-t...-couplers.html
Old 04-11-2014, 09:50 AM
StealthFRC
StealthFRC's Avatar
Dss couplers here, no issues so far.
Old 04-11-2014, 10:13 AM
breecher_7
breecher_7's Avatar
If people are interested in Billet ones I can make them and I can probably do it cheaper than you can buy them anywhere online...
Old 04-11-2014, 10:14 AM
Horps27
Horps27's Avatar
I see the DSS ones are for 12mm bolts, i have a 98, doesn't it use 10mm bolts?
Old 04-11-2014, 12:13 PM
breecher_7
breecher_7's Avatar
Yes, just drill it out and re tap it 12mm.
Old 04-11-2014, 03:49 PM
JDS99
JDS99's Avatar
Please don't do this unless it's professionally done to ensure it's drilled and threaded straight, and accurately located. Even then, I still would advise against it. For the money, you could just covert to 12mm tube assembly. Drill and tap the threads far enough out of tolerance and you'll be primarily loading one fastener over the next.
Not to mention you can't use a 12mm coupler in a 10mm tube assembly, they are different thicknesses and the assembled length will be wrong.
Old 04-11-2014, 03:57 PM
Patches
Patches's Avatar
I have a 12 mm drive shaft with just 7700 miles on it I would be willing to sell. It comes off of this assembly from my 2002 coupe.
Old 04-11-2014, 07:44 PM
slow ride
slow ride's Avatar
[QUOTE=JDS99;
Not to mention you can't use a 12mm coupler in a 10mm tube assembly, they are different thicknesses and the assembled length will be wrong.[/QUOTE]
What he said. Thickness is different. I did notice that using 2 zr1 couplers and a 12mm driveshaft make up the length difference to fit into a 10mm housing. Good for a spare I guess or slight upgrade over a standard 12mm.
Even stock 10mm bolt versions can take a beating if its a GM one or equivalent quality. It all depends on driving style, tracking, etc. all play a role in that will work for you. I've seen cheaper aftermarket couplers rub the tube from flexing to much. I think you can get GM ones for a little over $100 each.
Old 04-12-2014, 03:06 PM
JDS99
JDS99's Avatar
My first set of 10mm DSS poly couplers rubbed the inside of the housing BAD under load. They ended up sending me a new set under warranty.
My last set of 12mm DSS poly couplers had some very small rub spots when using the stock driveshaft. I think the stock shaft flexed enough under boosted 402ci loads. Hopefully no longer with the 3.5" DSS shaft in there now. Time will tell.
Old 04-12-2014, 05:03 PM
Patches
Patches's Avatar
The rubbing due to whip is one of the reasons I went with a cf shaft.
Old 04-14-2014, 01:04 PM
WIKU
WIKU's Avatar
Originally Posted by algZO6
RPM rebuilt mine with ZR1 couplers
Can u please explain to me how they were able to do that. Zr1 are different sizes, I was told.
Maybe I was misinformed.
I have mine apart now, and looking to upgrade. Let me know what parts are necessary. Thanks
Old 04-14-2014, 01:14 PM
Patches
Patches's Avatar
I'd like to know as well. I would guess that they machined the shaft ends to accomodate the thicker couplings if the ZR1's are thicker. Course, that would weaken the shaft ends slightly. Anyway, would be great to know what was done.
Old 04-14-2014, 01:49 PM
  #33
slow ride
slow ride's Avatar
The difference in size is just thickness from a 12mm stock vs a 12mm zr1. So they order a driveshaft just a little bit shorter to make the zr1 couplers fit.
Old 04-14-2014, 01:54 PM
  #34
WIKU
WIKU's Avatar
Just talked to rpm. They machine both ends of drive shaft, and the two flanges down.
Can u say MISSION!!!!
They Told me just do poly set up. .
Or second option is use the stock couplers and take it apart everytime it starts to crap out
Old 04-14-2014, 02:13 PM
  #35
Patches
Patches's Avatar
So far, I'm doing poly/solid with the LG cf shaft.
Old 04-14-2014, 02:27 PM
  #36
Horps27
Horps27's Avatar
Best options for the smaller/older tube on my 98?
Old 04-14-2014, 04:57 PM
  #37
blm1171
blm1171's Avatar
I went billet on both with auto.
To Drive shaft couplers - stock, poly or ?
Old 04-14-2014, 05:48 PM
  #38
morris
morris's Avatar
Yea but how do you know when it starts to crapout?
Old 04-17-2014, 12:19 PM
  #39
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
This is how I could tell if they were going bad...
Generally there is a vibration that will start to occur in the driveline (at least with a stock driveshaft).
If a coupler is going bad, or a driveshaft is starting to bend...generally there is going to be a vibration and this is going to get worse with RPM. On a manual trans car this is pretty easy to test. With the car running, and in neutral (foot off the clutch) bring the RPM's up to say 3000 rpm, then 4000 rpm and if you feel a vibration push your foot down on the clutch. If the vibration goes away, then more than likely something is going on with the driveshaft.
Now that isn't to say it is a coupler going bad, or a bend in the driveshaft or something else...but at least it is going to point to the fact you better get the torque tube apart and check it.
Old 04-17-2014, 12:45 PM
  #40
morris
morris's Avatar
That's good to know at least I have something to look for. When mine went I was on the track and had been downshifting pretty hard most of the day, I could have caused the problem and had it go catastrophic all in that one track day which would explain why I didn't see any of the symptoms you outlined. Next time I pull the drive line out the sold ones are going in for sure.
Quick Reply: Drive shaft couplers - stock, poly or ?
