Alternator relocation to lower passenger side?
Old Feb 3, 2015 | 10:18 AM
westtexasbuff's Avatar
westtexasbuff
Default Alternator relocation to lower passenger side?
Anyone know of a bracket that will relocate my stock alternator to the lower passenger side? Thanks!
Old Feb 3, 2015 | 04:35 PM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
I've seen one for the passenger side from a company called AEI CNC. I've also seen people bolt them directly to the PS head.
You could also give D3 Performance in Houston a call and see if they have any suggestions or could fab something.
Old Feb 4, 2015 | 11:15 AM
Smoove's Avatar
Smoove
mini on mine.
not factory obviously but might help.
Old Feb 4, 2015 | 12:13 PM
westtexasbuff
Thanks I saw that one the other day, gonna see if it works.
Originally Posted by Smoove
mini on mine.
Is that a bracket, or just bolted to the head?
Old Feb 4, 2015 | 12:21 PM
douniasg's Avatar
douniasg
I think ecs has a bracket that mounts the alternator where the ac. I used a mustang alternator and mounted where the ac. I would do the mustang alternator for your budget build.
Old Feb 4, 2015 | 12:43 PM
westtexasbuff
ECS doesn't make them anymore. Got anymore info on the mustang bracket and what's needed for it? Will the stock alternator work with the bracket?
Old Feb 4, 2015 | 01:22 PM
douniasg's Avatar
douniasg
I used a mustang alternator and drilled the mounting holes bigger. That made it line up . When i get home i will take some pic and tell you what year alternator. I didn't have to use a bracket.
Old Feb 4, 2015 | 04:14 PM
douniasg's Avatar
douniasg
I used a 96-2001 ford ranger alternator. I had to drill the 2 mounting holes bigger so the bolts will line up the c5 factory ac tension bracket. All you need is alternator pigtail and wire it up. This was a better option for me then spending $300 for ecs bracket at that time.
Old Feb 4, 2015 | 05:43 PM
Smoove's Avatar
Smoove
It is a bracket for the Pro turbo kit cars. I had only one side of it....I had to make the "L" bracket myself. 1/4 inch steel, a hammer, and a drill is how I made the "L".
Old Feb 5, 2015 | 08:14 AM
westtexasbuff
http://i806.photobucket.com/albums/yy345/douniasg/20150204_1535211.jpg
http://i806.photobucket.com/albums/yy345/douniasg/20150204_1535441.jpg
http://i806.photobucket.com/albums/yy345/douniasg/20150204_1534331.jpg
Thanks a bunch for the pics. Can't really tell, but how is the belt routed?
Old Feb 5, 2015 | 08:56 AM
douniasg's Avatar
douniasg
The belt is routed like the ac belt on the balancer and uses the ac tensioner. I think I had to put a spacer behind the 5 rib alternator pulley to get it lined up. I didn't write down the size of the belt but its the same width as the ac belt.
Old Feb 5, 2015 | 01:07 PM
Josh@AandASuperchargers's Avatar
Platinum Supporting Vendor
I've heard of guys using this setup.
http://www.aeicnc.com/lsx-super-mini...or-kit-rh.html
Old Mar 14, 2016 | 07:12 PM
Fordchevy1017's Avatar
Fordchevy1017
4th Gear
Default Wiring problem
Hey I have the same thing going on. I used a ford ranger alternator (98 model 4.0) and I got It where the ac was to be clear of the turbo headers (ptk stype under hood same as pictured above) now the alt is not charging can u tell me what wires you put where maybe show some pics to help me out please . If so I'd appreciate it thanks man
Old Apr 21, 2016 | 03:33 AM
Chris Stewart's Avatar
Chris Stewart
Bump, I would like to know too. Any pointers?
Old Apr 22, 2016 | 06:24 AM
dopefedz's Avatar
dopefedz
Couple of pics of the AEI CNC bracket. Really nice piece and the owner is very helpful. This is mounted in my Fbody but I am using it to run the alternator on the corvette beltline off the 4 rib portion of the balancer.
Used this setup to run the C5 blower bracket in the car.
Old Apr 22, 2016 | 07:47 PM
Fordchevy1017
4th Gear
Default Update on the ford alternator
I'm running this on a 97 tt forward facing and it alms works great but I'm having an issue with the belt staying on so I'm trying to find a different pulley on the alternator to use
Old Apr 22, 2016 | 09:13 PM
Chris Stewart
Aww man, not belt problems! That's why I went turbo in the first place lol
That looks nice. The Ford alternator also looks like a legit solution with easy mounting. Going to research wiring diagrams and try it out.
To Alternator relocation to lower passenger side?
Old Apr 24, 2016 | 01:24 AM
Chris Stewart
Making some progress today. Got a Ford Ranger alternator bolted up using the top 2 a/c mounts. It had some lower interference with the cradle, so hacked off some of the alternator case.
Added a big washer behind the pulley help to line it up. Ended up with about a 39" belt. Got a harness from the junkyard for $5, pulled it from an Explorer with a 4.0. Found some wiring diagrams online for Ford and GM, just need to match them up.
Going pretty well so far. Thanks to the forum, otherwise I would've never thought of doing this.
Old Apr 24, 2016 | 10:28 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11-'12
Very cool. Once you figure it out and make it easy for the rest of us, I think I'll end up doing it too. I never liked how the alternator sits high on the ds.
Old Apr 25, 2016 | 02:51 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Came across this although I don't know anything about it.
http://aeroflowperformance.us/shop/g...nator-bracket/
