ecs instal
Received 1,261 Likes
well, i understand, it the oil catch can. i have also figured out, that the big washer is the restrictor plate and goes into the neck of the air filter. it apparently is retained by the three screws horizontally. (i dont like that.)
but it took me a couple of hours looking on pictures in the other threads to figure in out.
well, biggest problem: they tell you to crack off the idler pulley bracket. thats bad. it seems to be part of the block casting. i will have to deinstall the system every other year for inspection purposes. is there a way to use the new idler with the stock belt?
CorvetteBrent (09-10-2018)
install another bracket that still has the idler ear intact... if you don't want to use their idler you don't have to, just leave it off and install the rest of the kit as you normally would... the earlier c5 bracket isn't as strong and there is a possibility of it snapping that ear off from the added belt tension, but that doesn't seem to happen very often... your call
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
Thanks for helping him out guys, I have been busy today and not on here much.
OP, the bracket is very inexpensive if you wanted to return it to stock, or just leave the fixed idler from us on the car and sell it without it. Either way I recommend you installing it, it's very easy to do IMO.
Received 1,194 Likes
St. Jude Donor '15
so you are saying, the new idler will work when converting back to stock, right?
btw, chris sais to cut the 4" hose and use part of it on the tb. i doubt it will work and am not looking forward to cutting it.
the actual build will not happen very soon, its too cold in the garage (i dont have a lift). but i have been thinking about the options i have. in the end i will probably end up with a sd setup, but i would like to go step by step using the maf first. so can i use the stock maf with the standart kit (i understand 7-8 psi of boost)? i read somewhere that the 2000 maf only goes to 11 750 hz. alternatively get a bigger maf, but which one. you read so many bad things about after market mafs. on the other hand, maybe its not worth it dishing out another $500+ and i should just max out the original maf with lower boost, see how everythig works and move on to sd.
any thoughts?
any thoughts?
St. Jude Donor '15
ecs instal
any thoughts?
any thoughts?
apparently the same intercooler used in the c6 is being used in the c5 kits now and the bigger intercooler is an upgrade... the intercooler the op has also appears to have cast end tanks, the older ones were made out of sheet metal and had nice welds all the way around them
any thoughts?
any thoughts?
Yes, we had to bend to what the market wanted basically. Not everyone wanted or needed a $1,000 intercooler apparently so those people would go with another brand to save money. We opted to make it an option after an over seas dealer wanted bulk kits with the smaller intercooler, we kept the option from there.
We have been 8.56 with the C6 intercooler btw, others have been faster.
#33
#34
#35
where does the air filter go with the big cooler?
btw, explorer opens the instructions incl. pictures.
a hint to ecs: if you ship a kit overseas, it would be a nice idea to include a 3/16 allen wrench for the brass plugs. they are awfully hard to get over here.
#38
the top cover is cut out different and the filter sits right on top of the intercooler
