Help with wotbox
Old Feb 8, 2015 | 02:28 PM
all4spl's Avatar
all4spl
Default Help with wotbox
So I installed wot box. But it doesn't work. As far as clutch sensor, which one do you use? The black one against the firewall or the resting one in front of the clutch arm? I used the grey one in front that is active when clutch is out. 2 step won't activate though. I tried the option in software for invert and it still doesn't work.
Old Feb 8, 2015 | 05:12 PM
StingrayRebel's Avatar
StingrayRebel
http://www.npcompleteperformance.com...x/instructions
Old Feb 10, 2015 | 08:00 PM
MotleyDrew's Avatar
MotleyDrew
pm me your email addy...will send you a file. A couple of the instructions in the link above are incorrect as I noticed when I tried to install it. I spoke with N2MB and they have heard the same issues and sent me the file I will share with you.
take care
Old Feb 13, 2015 | 02:43 AM
GenerationX1's Avatar
GenerationX1
Never heard of the WOT box before.
I'm running the LS MSD 2-Step. Plug and play basically...
Old Feb 13, 2015 | 08:23 AM
MotleyDrew's Avatar
MotleyDrew
It is a multi functional box. It does the following:
- 2 Step
- Wide Open Throttle shift (by pulling ignition for milliseconds when clutch is depressed)
- Soft touch rev limiter
- shift light
It is much more difficult to install but it has many more functions.
take care
Old Feb 13, 2015 | 12:05 PM
StealthFRC's Avatar
StealthFRC
I'm using it, no lift shifting is great.
I have not used the 2 step yet, I'll have to see how I have it hooked up, it's been awhile. I know I had to change a bunch of settings in the program.
Old Feb 13, 2015 | 01:58 PM
GenerationX1
- 2 Step
- shift light
take care
Thank you for that info Sir!!
I may have to check into one of these.
Old Feb 17, 2015 | 04:21 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Neat box. Piqued my interest for many reasons. I need a window switch anyhow, no lift shift is very desireable so as not to lose turbo boost during shifts, two step to leave on boost, windows switch integrates with no lift shift.
One question is the two step cutting ignition or retarding it? I wouldn't expect it to build boost on the line if it just cut spark. But the videos show turbo cars building a bit of boost on the line.
Old Feb 17, 2015 | 04:29 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Originally Posted by 5 Liter Eater
Neat box. Piqued my interest for many reasons. I need a window switch anyhow, no lift shift is very desireable so as not to lose turbo boost during shifts, two step to leave on boost.
Another is I'm assuming it's wired into the clutch lockout switch and not the fully depressed switch.
Wired to top clutch switch (gray wire IIRC)
Cuts power to the coils.
Shotgun blast on the shifts.
Old Feb 17, 2015 | 06:16 PM
MotleyDrew's Avatar
MotleyDrew
Like Mr Bret said ,cuts ignition. You can actually set the milliseconds to your desired amount as well
You can set the clutch depression amount as well.
Pretty trick item that I have installed but not yet tried as I have 5 ft of snow outside
Old Feb 17, 2015 | 06:21 PM
5 Liter Eater
St. Jude Donor '11
If it's just cutting ignition I wouldn't expect it to build much if any boost on the two step. Delaying it like the LPE box does is what spools the turbos. Still, for the price of a window switch I get that and no lift shift which is really appealing.
Old Feb 17, 2015 | 06:27 PM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
My understanding is that if you cut ignition and not fuel, it dumps raw fuel on the hot turbine wheel and some combustion takes place in the housing causing the turbine wheel to increase speed, i.e. spool.
This is the theory, but not sure how it plays out in the real world.
Old Feb 18, 2015 | 10:33 AM
5 Liter Eater
St. Jude Donor '11
I suppose. But retaerding the spark excessively ensures that the mixture is ignited while leaving the cylinder. In any case I'm not terribly concerned about hot much boost the two step is able to build. If it allows me to flat foot the gas and bang gears smoothly and control the nitrous accordingly I'll be happy.
Old Feb 18, 2015 | 10:44 AM
Turbo-Geist
I just read the fine print and it says: "We recommend that the mufflers be welded in place especially on black C6s."
Old Feb 18, 2015 | 10:51 AM
5 Liter Eater
St. Jude Donor '11
Actually there is a higher likelyhood of muffler loss if it's going to be popping and spitting on the line and in between shifts.
Old Feb 18, 2015 | 11:31 AM
StealthFRC's Avatar
StealthFRC
its VERY loud lol
one of my friends got a little excited in the video
Old Feb 18, 2015 | 11:56 AM
BLOWNBLUEZ06
Originally Posted by StealthFRC
its VERY loud lol
OMG that video's so hard to watch with him moving the camera like that.
To Help with wotbox
Old Feb 18, 2015 | 12:38 PM
StealthFRC's Avatar
StealthFRC
yea crappy vid lol
no need to watch just need to turn the volume up and listen
Old Feb 19, 2015 | 11:08 AM
StatmanRN's Avatar
StatmanRN
I can build 2-3# at launch with the WOT box. Which, as it turns out, just exacerbates the traction problem off the line.
Old Feb 19, 2015 | 11:24 AM
5 Liter Eater
St. Jude Donor '11
Good to know. Thanks.
