Reduce Engine Power error - Suggestions?
Old Aug 14, 2002 | 12:23 AM
esch's Avatar
esch
Default Reduce Engine Power error - Suggestions?
OK
recently got the procharger installed....
keep getting "reduce engine power" error and the associated check engine light and power reduction.
It goes in the shop tomorrow for the LS1 edit routine (Again) -
Any suggestions as to what to look for?
Old Aug 14, 2002 | 02:32 AM
Mike Morgan's Avatar
Mike Morgan
Default Re: Reduce Engine Power error - Suggestions? (esch)
'01 and up have add'l power management problems that are unrelated to torque management. If you have an auto, I'd guess LS1-edit will not be able to address the issue.
If you don't have any luck with LS1 edit, shoot me an email and I'll see what we can do for you.
Rob Raymer's Avatar
Rob Raymer
Usually this is related to the MAF or throttle body. Do you know if the throttle body blade was drilled when the blower was installed? If so, check to see if the whole was drilled too large.
Also, try swapping MAF's with a known good MAF, and clear the computer before starting the car again.
I have also seen this caused one other time when the computer was being "flashed" with a new program. It went away once the computer was re-flashed.
Hope that helps,
Rob Raymer
LS1 Motorsports http://www.LS1Motorsports.com
Old Aug 15, 2002 | 08:20 PM
JC-5's Avatar
JC-5
Default Re: Reduce Engine Power error - Suggestions? (Rob Raymer)
Also, check all electrical connections at the throttlebody.
To Reduce Engine Power error - Suggestions?
