First Nitrous setup - advice needed
Old Jul 6, 2015 | 07:56 PM
Arg0413's Avatar
Arg0413
Default First Nitrous setup - advice needed
I'm about to spray my car for the first time and I've been reading up but want some opinions and critques of my setup. My car is a '99 C5 with a twin filter intake, BBK SSI, LG Street LTs, and a tune by EPS. I recently purchased a NOS 78MM plate kit, have the NOS TPS and window switch, and going with a LPE LNC-2000 to pull timing when it's armed. I'm going to run a 100HP shot. Is this a flywheel or a RWHP rating on the wet systems? I plan on running NGKBR7EF plugs gapped at 32. I'm concerned about the fuel system and getting a pressure drop when I first engage it and going lean. Can the stock C5 fuel pump support this power and prevent a pressure drop or should I upgrade my fuel pump before I spray? What setting should a FPSS be set at? I've read that some people have had problems with them tripping from the initial pressure drop, which makes me not want to install one. Insight from you experienced guys would be appreciated.
Old Jul 7, 2015 | 08:01 AM
NJ Torque's Avatar
NJ Torque
I would atleast install a walbro 340/in tank pump before spraying... just as a peice of mind.
Old Jul 7, 2015 | 11:10 AM
Arg0413's Avatar
Arg0413
I didn't know you could install a 340 in a C5.. The kits I'm seeing are the Lingenfelter Walbro 255 and the Racetronix 255 with the upgraded witing harness. Would either of these work well?
Old Jul 7, 2015 | 11:40 AM
Nitrous Express & Snow Performance's Avatar
Supporting Vendor
You'll be fine with a 100 shot on a mostly stock setup
Old Jul 7, 2015 | 12:46 PM
Arg0413's Avatar
Arg0413
There is no need to worry about my fuel pump with a 100 shot on my mostly stock car? Do I need to upgrade it once I do Heads and cam next year?
Old Jul 7, 2015 | 01:10 PM
Supporting Vendor
I would when you do H/C
Old Jul 7, 2015 | 01:19 PM
Arg0413's Avatar
Arg0413
so there's no reason to worry about a pressure drop right now with my stock pump and only having intake and LTs?
Old Jul 7, 2015 | 02:11 PM
c_white's Avatar
c_white
I wouldn't worry about a pump until u do the 150 pill ..
Old Jul 7, 2015 | 02:19 PM
Arg0413's Avatar
Arg0413
I appreciate everyone's quick response! Makes me feel better about spraying on the stock pump, all my buddies have F bodies and think I shouldn't, I keep telling them the C5 pump can handle it.
Old Jul 9, 2015 | 12:44 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
I've sprayed 100 off the rail on a stock fuel system and only the basic bolt-on stuff and it ran great. I also used the LNC-002 to pull timing.
On a mostly empty bottle I ran 10.84@124 running really rich.
Have fun with your new setup!
Old Jul 9, 2015 | 08:43 PM
Arg0413's Avatar
Arg0413
Sounds like a plan! You ran 10.84 on spray with bolt ons?!?!
Old Jul 10, 2015 | 10:12 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
Yep. Wish I had a full bottle and good pressure.
Kooks long tubes, off road x pipe, stock Z06 cat back, 4.10 rear, stock clutch.
NA tuned by Doug@ECS.
Old Jul 10, 2015 | 06:54 PM
Arg0413's Avatar
Arg0413
All I have to say is That's awesome!!!
I have LG Street LT's, off road x pipe, no name cat back that came with car, 3.42 rear, and stock clutch.. I'll be very happy with low 11s!!!
Old Jul 10, 2015 | 08:38 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
That same night I took the bottle out and ran 11.64@119 NA.
Don't fear the gear! Go with 4.10s.
To First Nitrous setup - advice needed
