I needed the radiator, fans, and 160* thermostat with a bypass drill in it to keep my temps in check with an iron block and Ysi, and will be added an oil cooler this winter.
It's up to you. I did a 180 and didn't see much change so I went with a 160. But I run 20w50 VR-1 oil. So oil temps are higher and I needed all the cooling I could get.
Now I'm looking at the slp 160 for my 2002 but it looks like they all come with the hose neck. Can I just get the thermostat or so I need the whole assembly?
certainly get the 160* t stat. i don't think radiator is necessary unless you live in NV or AZ but the upgraded dewitt single brushless fan was a game changer on my LSX iron block D1SC car.
