IFR table
Old Oct 22, 2015 | 01:56 PM
Blow Torch's Avatar
Blow Torch
Default IFR table
For anyone running 80lb injectors; would you mind looking at your IFR table and give me the 1st (0) and last (80) numbers?
I am trying to make sure my table is set up correctly. Seems high
Old Oct 22, 2015 | 03:41 PM
jimbos'ss's Avatar
jimbos'ss
Old Oct 22, 2015 | 04:06 PM
Blow Torch's Avatar
Blow Torch
Thanks Jimbo
I'm
92.4 - 101.2
Looking at some of the smaller injectors as reference, (42,60's) it looked a little high.
Old Oct 22, 2015 | 07:58 PM
jimbos'ss's Avatar
jimbos'ss
No problem. Yeah that's a bit high.
Old Oct 23, 2015 | 03:18 PM
Milan's Avatar
Milan
Without knowing if the tune is scaled and what fuel pressure people are running it's kind of irrelevant.
Old Oct 23, 2015 | 07:40 PM
Blow Torch's Avatar
Blow Torch
True; But looking for a pattern and a few quick calculations based on the injector size they are running and it "seemed" mine were et up a little high
Just having some AFR issues and trying to look at everything.
Old Oct 23, 2015 | 10:10 PM
Shoaf85's Avatar
Shoaf85
Are your injectors rated at 80lbs @43.5 psi and I'm assuming you are not running a boost referenced fuel psi regulator?
Old Oct 24, 2015 | 02:34 AM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
^^^^^ this! Because an injector rated at 80 Lbs @ 43.5 psi is going to flow more @ the LS1 base fuel pressure of 58 PSI. Looks like your IFR numbers you have in your table are at 58 psi. (Base LS1 fuel pressure)
Check this out..
Old Oct 24, 2015 | 02:55 AM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
You can chase you tail all day on this table. Being off a little isn't a big deal.
Old Oct 24, 2015 | 07:57 AM
Blow Torch's Avatar
Blow Torch
Yes guys, thanks
They are rated at 80 at 43.5 and I'm running 58psi. I calculated them with the hp tuner tool and got the 92 at zero. It seemed high per others but close) The spread was also got my attention. Per my tuning manual, I take the spread from high to low of my original table (2.79) and add that to the 92.x and put in the 80 area and interpolate between. My 80 table was originally 104, for a difference of 12.xx), thus my concern
I am having an issue with the AFR going back and forth (slowly) from about 11.xx to 18 at steady throttle. It appears my O2s (brand new) are not oscillating fast enough, but instead, SLOWLY go from high to low causing the rich lean condition.
Always something
Old Oct 24, 2015 | 08:00 AM
Blow Torch's Avatar
Blow Torch
Heres a short scan if it matters. (Im looking at the AFR on the in car wideband)
File Type: hpl
Old Oct 24, 2015 | 03:51 PM
CamminC5's Avatar
CamminC5
I remember reading something a while back about a guy who replaced his O2's with some brand from the parts store and something similar happening. Don't quote me on this, but maybe someone will chime in that has more knowledge than me.
Old Oct 24, 2015 | 04:27 PM
Blow Torch's Avatar
Blow Torch
That would bite but might explain this PITB issue. It just doesn't make since. The O2s are just slowing going up for a while and down for a while
Old Oct 24, 2015 | 07:40 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Not all replacement 02 sensors are created =. That's for sure.
Old Oct 25, 2015 | 01:45 PM
Blow Torch's Avatar
Blow Torch
Is there anything else that would cause them to cycle so slowly?
Old Oct 25, 2015 | 04:40 PM
CamminC5's Avatar
CamminC5
Were they plugged back in right? Any chance the harnesses going to car were crossed?
Old Oct 25, 2015 | 07:43 PM
jimbos'ss's Avatar
jimbos'ss
If you command OL what's your error% looking like?
To IFR table
Old Oct 26, 2015 | 07:31 AM
Blow Torch's Avatar
Blow Torch
No chance of that. I have the harnesses zip ties right above the header with no room for them to reach the other
I have not tried commanding an AFR. I didn't have the wideband hooked up to HP. I was noticing the big AFR swing so I hooked up HP to take a look at the STFTs and noticed my O2s were barely moving. I purchased the new ones and then noticed that they were completely opposite and just swinging high and holding, then swinging low and holding. Figured I needed to figure out that issue or it would never run correctly
Old Oct 26, 2015 | 10:41 PM
jimbos'ss's Avatar
jimbos'ss
I highly recommend getting your wideband plugged into the EIO and setting up an AFR error % histo. When I say commanding OL. That means forcing it to stay in open loop mode and taking the narrowbands out of the equation. If you're chasing your tail in OL mode then it's something in the calibration. I already have a few ideas what I think it is, but good logs are needed to verify.
Old Oct 27, 2015 | 11:24 AM
Blow Torch's Avatar
Blow Torch
Thanks Jimbo
I will be back Friday, and Ill try to get a chance to work on it and get a log.
