IFR table
Old Oct 30, 2015 | 12:46 PM
Blow Torch's Avatar
Blow Torch
I got a quick scan with wideband hooked up and OL commanded (set water temp activation to 240* in table). I didn't know that the AFR error was not set up, so I have ARF readings but not error. In both the histogram and graph, it is showing around 13-1 at idle and when I run it up to around 1800 it goes down to around 11-1
I have the AFR commanded 14.7 in that range
The VE table is already around 1/2 what other tables are, and it is still pig rich
Any ideas??
File Type: hpl
File Type: hpt
Old Oct 30, 2015 | 01:18 PM
jimbos'ss's Avatar
jimbos'ss
Any ideas??
When I get home I'll boot up my laptop and look at your scan and bin file.
Old Oct 30, 2015 | 02:08 PM
Blow Torch's Avatar
Blow Torch
Thanks Jimbo
Old Oct 30, 2015 | 09:14 PM
jimbos'ss's Avatar
jimbos'ss
PM sent
Old Nov 2, 2015 | 10:55 PM
jimbos'ss's Avatar
jimbos'ss
80's.hpt
copy and paste the injector data from this file. This is good data for the 80's pending how your fuel system is setup.
Old Nov 3, 2015 | 08:09 AM
Blow Torch's Avatar
Blow Torch
Attachment 47927919
Installing Data now
Thinks Jimbo
Old Nov 3, 2015 | 03:53 PM
Blow Torch's Avatar
Blow Torch
Here is a short scan with changes in injectors
File Type: hpt
File Type: hpl
Old Nov 4, 2015 | 10:27 AM
Blow Torch's Avatar
Blow Torch
PM sent
File Type: hpl
Old Nov 6, 2015 | 09:49 AM
Blow Torch's Avatar
Blow Torch
Jimbo
Here is a scan with the changes to match the 80 file
File Type: hpl
Old Nov 11, 2015 | 02:21 PM
Blow Torch's Avatar
Blow Torch
Latest scan and Tune
PM sent
File Type: hpl
File Type: hpt
Old Nov 11, 2015 | 06:22 PM
Shoaf85's Avatar
Shoaf85
I glanced at the scan real quick. You need to add commanded afr to the table in order to log afr error. Seems odd to me that your stft's are 1-2% when idling at rich afr/s (11-12) then when holding rpm at 1500 stft's go up to 10ish% when the afr is actually way closer to what it should be commanding. Is your wideband setup correctly/does the display on WB read same as in the scanner?
Also is that a cold start ? may be good to add engine coolant temperature to primary table as well.
Is this supposed to be a speed density only tune ? (the maf is still enabled if so)
Old Nov 11, 2015 | 06:54 PM
Shoaf85's Avatar
Shoaf85
Going thru the tune a little more in depth shows a few things that need to be changed, fuel transient parameters need to be altered with this size injector as well. A lot of times this will cause a rich condition that wont change regardless of changes made to the tune. Bring it to Concord NC and I will do a street to for ya or dyno tune if you'd like
Old Nov 11, 2015 | 10:39 PM
  #33
jimbos'ss's Avatar
jimbos'ss
Haven't had a chance to look at the last two scans. Shoaf may be correct about the transient tables. I still suspect proportional tables are the problem. We need a faster way to communicate. Hit n miss over PM's is gonna take forever.
