I am going to be ordering a YSI soon for my 2003 ZO6. My good buddy who’s been a mechanic for about 9 years suggested we do it our selves. Now he is good, but never installed a blower or really dug that deep into a corvette like that. For the roughly 8-10 hours it takes to install, how bad is the install? What are the major problems people run into? I will be doing an upgraded fuel pump, injectors, and 8 rib conversion to get everything I need for the future while its apart. From there it would need a tune which I am not sure if the car can be driven that far right after install but a trailer isn’t an issue. I would love to say that WE did the project, and I think it would be awesome to experience doing it, but the thought always is running into a problem that cant be solved or messing something up. Don’t want it to turn into a nightmare and leave me wishing I should have took it in!
You can drive the car with all done to the car OTHER than leave the stock INJ in the car and just don't get into the car at all on any runs r WOT. Chg out the inj at the tuners are let them do that for you just get that part up front. Are like you said just tow the car to the tuners...
The hard thing will be doing on it is drilling the crank to put a pin into it. Good luck and you will love the YSI.. Robert
The only thing difficult is moving the power steering rack out of the way.
The above post talks about being careful to not get into boost. Its really not that big of deal as the computer won't actually allow it to go into boost...nothing significant anyway. It will see more air moving then expected and throw it into self preservation mode. I drove my car a lot (at least 1000 miles) after the SC install before I bought HPTuners to learn to tune it myself. If I stepped on it a little too hard...right into limp mode. I suppose if you tried to hurt it you could. If you have a boost gauge you will see when its starting to build boost.
Our new bracket design with the billet tensioner makes installation, as well as any future belt changes, MUCH easier. Our new inlet duct is also much easier to install.
Originally Posted by Tusc
Agreed: the only truly difficult part was changing the accessory bracket itself and the power steering pulley.
Pinning the crank is just a long process of removal and reinstallation.
The OP has an '03. The later C5 does not require the accessory bracket (alternator and power steering) change. He should already have GMs updated version.
__________________ PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036 WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
I dont think its necessarily difficult. But I seriously doubt it can be done in 8-12 hours if its your first install. Granted, I didnt have a buddy that was a mechanic to help, but mine took me 2-3 days....and then a few more days to work out bugs for this...bugs for that. Unless everything works out perfectly (which didnt happen with my used kit), I doubt youre 100% the first time you put it all together.
Now, with a new kit, it may can be done in 1-2 days without many hiccups afterwards.
All told, I'm at about 3 months working a few hours a week on it. Ive driven it a handful of times in that period, and usually ended up putting it right back up on jacks to start tearing down something.
Undoubtedly, you will know EVERYTHING about your car by doing this. Its great, and I wouldnt want it any other way.
Nope this car is definitely not my daily, she has only 20k and is in flawless shape. I want to take my (our) time with the build. I seem to luck out on quite a few things it being a later model. I think it would be easier and make sense trailering it to the shop (40 miles away) for a tune and triple checking our work, I'm fine with that. I just gota decide if I'm gona go ahead and do an upgraded fuel pump instead of the bp, which not sure if it's needed but makes sense. I'm trying to do everything right, and get all the necessary things to make it as most efficient (I'm on the stock 347, for now) which eventually down the road I plan to forge or swap completely
I talked to josh about it a few months back and was ready to order but an emergency came up, so now is a much better time to do it, not to mention that was before I changed my mind from a v3 to the ysi lol.
How is the tapping into the oil pan for the supply line? That's the other thing that made the worry besides the pinning the crank
Tapping the oil pan was almost as brutal as pinning the crank. Its hard to get in there to see what you are doing, and the location of the hole does matter! Dont get too close to the oil pickup, go as far right as possible.
With your YSI, i doubt you will have enough fuel pump, even if you are methanol reliant. Just depends on your horsepower goal.
My suggestion is to do it all right this time so you arent having to go back later and do more upgrades if you want to turn up the boost or change out components (heads, cam, more cubic inches).
You're gonna need both a better fuel pump, and a BAP. A harness isn't a bad idea, either.
I will need a boosta pump on top of the better upgraded fuel pump?? And can you elaborate on the harness? Thanks
Yeah, I ran out of fuel after installing, during dyno tuning. With the included A&A pump, it started dropping pressure about 5500 RPMs. To be safe, I added a Magnaspark BAP, or rather, the tuner did, which enabled good FP past redline. The Racetronix (sp?) wiring harness helps in voltage drop, too. I see you're getting a YSI. I would think this would be even more demanding of FP.
I've had plumbers do their own SC install over the weekend. It's not that hard, but time consuming if you have never done it. Leave stock injectors installed and you could drive it gently to the tuners shop and then swap in the big injectors in the parking lot and let them tune from there.
I'm certainly not a plumber, but I did my own install in my garage, on jackstands. I had to drive 200 miles to the tuner trying not to get any boost. I do think it took me more than a weekend. The clutch install was more difficult, IMO.
I don't think the new V3 kits require you to tap into the oil pan... as they are self contained. Unless you choose to get the non self-contained version lol.
I just bought a V3Si and that's what I was told-- that the previous versions were not self contained like the V3. I will not have to tap into the oil pan when I install.
Also, can I ask why you changed your mind to a ySi?
Im about to do a install myself in the near future. The only thing I was worried about was pinning the crank (don't want to go to far) and wiring the bap. Im going to give myself a week or so for the install, just a few hours a day. Also its not my daily.
just lay the pin next to the drill bit and use a piece of tape around the drill bit to mark the length, that way you don't drill too far... if you get a racetronix harness the bap is plug and play
I have no idea why i didn't think of that, was still early in the morning or im just a moron lol. Ill look into the racetronix for sure. Thanks again for the help neutron82.
