Too much timing?
#61
Do you log EGTs on individual cylinders Pekka?
#62
Doug has run 8 second cars and has EGT data to back it up so to claim there is no difference with meth on the front two cylinders, you can have your opinion but I'm going with the guy who builds thousands of supercharged vettes and logged results with individual cylinder EGT sensors.
#63
Do you wear your helmet on the street? Your dyno numbers indicate your car should be quicker than 13.99 seconds. Do you have a parachute on your car? I would hope 900rwhp could hit over 150 mph on the street.
I guess it's a form of virtual reality?
#64
Not in my own car, but some of those I've tuned it has been helpful.
It is probably overkill for engines having less than 1000 or those not having an aftermarket controller.
Back to the topic itself: usually it's too little timing in cruising areas which makes your car not performing as it should. While fuel economy may not be that important for most of the folks, heat typically is. And that is something easily monitored by exhaust gas temperature gauge, if AND if there's any reason to think it may be related to timing advance.
If I would be you, I'd install one of these:
http://www.plxdevices.com/EGT-Exhaus...7346002184.htm
Just to be sure.
Just to be sure.
#65
http://injectordynamics.com/articles...racterization/
#66
Just to be sure.
Just to be sure.
This one looks interesting. It's a wideband and will also accept an egt sensor.
http://www.14point7.com/products/sig...-pure-plus-2-1
#68
Well this thread got interesting lol.
Anyway, he did wind up reading a few degrees of knock so he bumped it down to 16 or 17 & all is well now.
If it made 717 on 20*, what do you guys think it makes with 16 or 17*?
#69
Hard to guess on how much power you lost...they gain quite bit of power with each degree up to a point, that point is usually where you should stop..lol
From 20* down to 16* I'd say 40hp loss or so....maybe a bit more. Purely guessing..
Mine was gaining 20hp per 1 degree of timing from 15* up to 17*. Then from 17* up to 18* it only gained 10hp....so I knew it was pretty much at its peak for gains... As I mentioned, I turned it down to 15* right after the hero pull so I wouldn't have to worry about it.. Ran it like that for 8k miles...countless highway pulls and 1/4 passes... Eventually, after a cam swap, it detonated on 15* and nipped 4 pistons.
Now I run 13*, BE8EF plugs and keep my fingers crossed. If I know I'm gonna be making highway pulls, I dump 5 gals of C16 in it with a half tank of 93. Overly cautious? Yes.... But 3 engine rebuilds in 3 years will do that to ya..
#70
Just hit up NolaMSP and add a few gallons of 104 unleaded if you'll be out beating on it a lot. Before I switched to e85 I had a pump tune and a 104 tune.
#72
Tuning was of course done without meth, right?
#73
- 9.5:1 LS3 with forged internals
- Lingenfelter GT7 cam (208/230 at .050)
- TR6 plugs
- crappy california gas
- 22...24 degrees of advance at WOT
Too much timing?
- TR6 plugs
Too much timing?
#74
Wouldnt say it sounds dangerously high but as you know there are other variables. Although I've no experience of how bad Cali fuel might be. From the amount of talk about fuel in the US, how it seems to vary so much baffles me.
Only way to determine if there is any risk is to listen for any detonation at or around that level of timing and driven under the sort of conditions/loads the engine will see....using whatever fuel they intend to keep using.
#77
I'm not the most experienced guy in here but my previous motor was 9.5:1 compression with dual methanol and 91 pump gas and the tune sucked in a lot of other ways too but at ~11 AFR it blew up almost immediately after a 1/2 mile run with similar timing.
#78
What type of boost and how much boost ?
#79
Sounds suspect. Can you post the tune file and a log file with a WOT pull in a 1:1 gear preferably from 2500 rpm to the programmed rev limit?
#80
Sorry, but I've not been honest with you folks.
This engine does not exist.
If it would, then apart from the compression ratio and a tiny difference with the cam, it would be identical with a stock LS9.
www.lingenfelter.com/product/12638427.html
And stock LS9 tune.
And stock ignition advance.
Would it be too much with this kind of imaginary engine?
I don't know.
Maybe.
Maybe not.
We'll never know.
