Lessons in timing chains and one with no equal
Supporting Vendor
Thanks Jeff.
Supporting Vendor
ISIS SUCKS FAT CHOAD
I've installed a few of these now and I've had other engine builders compliment the robust chain these timing sets come with.
Purchase with confidence from blownbluez06@rktperformance.
While you're there for some additional insurance, purchase the cam hear bolt locking retainer plates he sells too! It's cheap insurance that your cam gear bolts will stay put. I recommend these things for anyone even if you have a bone stock timing set.
The following 2 users liked this post by MVP'S ZO6:
CorvetteBrent (07-09-2018),
SteveDoten (07-02-2023)
I'll be ordering one shortly for my new to me forged LS2.
Supporting Vendor
I do need to say that the LS9 timing gear is different than the LS3/7 timing gear and my dry sump LS3/7 lower timing gear will not replace the LS9, however, you can reuse the LS9 timing gear and replace only the top gear or now buy only the chain for 99.00 shipped.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
#34
Supporting Vendor
Thanks for asking. I would welcome anyone that's running my chain, good or bad to step in and speak. I've not been made aware of any failures to date. Up until my design, my favorite chain was the C5R chain. I like their thicker links especially, but only one of each pair of links is thicker. I never understood why, but I made sure that mine were equal thickness and made from top grade materials. All premium materials, stress relieved, heat treated and tempered coupled with thicker pins and oiling holes in the rollers to keep surface temps down are all part of the winning recipe.
I'm wondering what part of your timing chain failed. Have you looked at the valve tips for "stars" that indicate valve float? I may be stating the obvious, but valve float will increase the shock loads and lead to premature failure.
Let me know if you have any questions.
#40
