dead head fuel setup
Old Dec 13, 2016 | 11:15 PM
AtlasInTheGym's Avatar
AtlasInTheGym
Default dead head fuel setup
Hey has anyone ever ran a fuel dead head system like the one in this picture?
I have a racetronix 255 in tank and an external aem 400 that I want to run in paralell and I was wondering if it was possible with this setup. Going in an 01 base with a p1sc. I was hoping to use stock rails.
http://i321.photobucket.com/albums/n...ps62c51e7d.jpg
Old Dec 14, 2016 | 12:35 PM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
The problem with the dead head system drawing shown is any drop in pressure after the regulator will not be compensated for by the regulator.
58 psi upstream of the regulator does not guarantee 58 psi downstream of the regulator.
It can work, but it depends on how much power you plan to make and how far the regulator is from the rails.
Old Dec 14, 2016 | 12:53 PM
AtlasInTheGym
So the next question after that is the an4 port on the stock rails big enough for a return to the regulator?
Old Dec 14, 2016 | 01:37 PM
StuntHeavy's Avatar
StuntHeavy
My cars fuel system is deadheaded. A well reputed member here is the one who help me design it. Knowing him, I can't imagine he'd steer anyone wrong. The mindset was hydraulics is hydraulics, regardless of location.
Another nice aspect is it keeps the fpr out of the engine bay, keeping it cooler. Also, any fuel that makes it to the rails, gets burned. This helps with keeping fuel temps lower since you're not circuilating fuel under the hood, through the rails, back to the tank.
So far it's been good to me. Hasn't been on the Dyno yet, but I have ever intention of pushing the F1R to near its limits.
Old Dec 14, 2016 | 01:50 PM
Turbo-Geist
What does the saying "hydraulics is hydraulics, regardless of location" mean?
Old Dec 14, 2016 | 01:52 PM
Turbo-Geist
What is the maximum amount of power you are looking for this build to make? Power output will determine fuel requirements.
Old Dec 14, 2016 | 02:26 PM
StuntHeavy's Avatar
StuntHeavy
Well, a fuel system is essentially a hydraulic fluid system (unless you've got some serious cavitation or otherwise going on).
I can't speak for all regulators, but I know my Magnafuel has no restrictions and is a straight shot between inlet and outlet. The diaphragm and spring meter what goes to the return.
By principle, it's not possible to have (for extreme example) 40psi at the injectors and 58psi at the regulator inlet. Or at least, that's what that Pascal guy said once.
Old Dec 14, 2016 | 10:26 PM
AtlasInTheGym
650hp-700. Off a boosted 383.
Old Dec 14, 2016 | 10:53 PM
AtlasInTheGym
Exactly what I needed. I work with fluid dynamics all the time and wasn't thinking of it that way. Once you said that it clicked.
Old Dec 14, 2016 | 11:06 PM
StingrayRebel's Avatar
StingrayRebel
my secondary is set up this way and probably very similar to stuntheavy's and the guy who helped him is probably the same guy who helped me... I have my regulator hidden out of the bay before the rails and my base pressure was lowered to 46psi... it has not given me an issue at all since I've had it set up this way, no fuel overheating, pump cavitation, nothing... I'm actually about to pull this setup off though and make the switch to e85 with walbro 450s in the tank
Old Dec 15, 2016 | 10:25 AM
etekberg's Avatar
etekberg
A change in pressure at any point in an enclosed fluid at rest is transmitted undiminished to all points in the fluid
Is your fuel system at rest?
Old Dec 15, 2016 | 05:06 PM
DW32's Avatar
DW32
Cruising
How is your system put together? Any pics?
Old Dec 15, 2016 | 11:01 PM
JDS99's Avatar
JDS99
I wouldn't call any system with a return, deadheading, regardless of where the regulator is. The reality is whether you have the regulator after the rails or before the rails, there is going to be a pressure differential locally in the rails every time an injector opens. Then consider the order in which the injectors are opening and how sequential it isn't as you move down the rail. It just doesn't matter. Put the regulator where you want, set your base fuel pressure, and tune vehicle accordingly.
To dead head fuel setup
