Intake Opinions
Old 06-06-2017, 01:26 PM
  #81
alxltd1
alxltd1's Avatar
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Originally Posted by X2142
Not even just a little bit? and what does IE stand for?
And honestly, I'll only see lowered rpms during first gear then after that i won't see below 4000, I believe, might be alittle higher than that
id est Latin for "that is" .
Old 06-06-2017, 01:57 PM
  #82
Volk2142
Volk2142's Avatar
Ooh lol I am stealing this knowledge
Old 06-06-2017, 02:26 PM
  #83
alxltd1
alxltd1's Avatar
Originally Posted by C5Natie
I can tell you first hand that the Sniper intake is not made by Holley and is identical to some you can buy on ebay. Holley does quality check them before reboxing them but I dont know if thats worth their markup.
I run an aluminum intake by Speedmaster, identical to the Typhoon by Profesional Products and Chinese as well. I however ported the crap out of it and slapped a 102mm tb on it. I figured an aluminum intake will hold up better to my 25psi.
How is your manifold performing. I have a PP Typhoon that I have had the flanges trued, as well as the TB mounting pad trued . This to avoid what was said to be a common problem with sealing. I am going to use the Fel-Pro raised bead gaskets also. Curious if you had any such issues with yours. Thanks.
Old 06-06-2017, 02:31 PM
  #84
alxltd1
alxltd1's Avatar
scientia bona est semper
Old 06-06-2017, 04:35 PM
  #85
C5Natie
C5Natie's Avatar
DON'T USE THE FELPRO GASKETS! You will have vacuum leaks. The best gasket for this intake is the Professional Products #52610. It matches the intake and cylinder ports perfectly and has a silicone bead on both sides where the felpro only had it on one side.
alxltd1 (06-06-2017)
Old 06-06-2017, 04:36 PM
  #86
Volk2142
Volk2142's Avatar
Lol lost me again haha
  #87
Volk2142
Volk2142's Avatar
I thought Fel-Pro had some of the best gaskets??
Old 06-06-2017, 04:38 PM
  #88
C5Natie
C5Natie's Avatar
I have yet to do final tuning but so far the intake seems to be doing just fine. Based on fuel the car is making around 820hp on 16-17psi of boost at 67% throttle. We should see 25psi or so at wot. Hoping to be on the dyno in the next week or so.
Old 06-06-2017, 04:40 PM
  #89
C5Natie
C5Natie's Avatar
In general they do but the one they offer to use with the typhoon intake is not very good.
Old 06-06-2017, 05:34 PM
  #90
Volk2142
Volk2142's Avatar
Nice! and thats strange though for one set to be bad for one intake lol
Old 06-06-2017, 06:29 PM
  #91
alxltd1
alxltd1's Avatar
"Knowledge is always good." in Latin.
Volk2142 (06-06-2017)
Old 06-06-2017, 06:31 PM
  #92
alxltd1
alxltd1's Avatar
Attachment 48100997
Attachment 48100998
Thanks, good to know.
Old 02-07-2023, 10:03 PM
  #93
Smitty's
2nd Gear
Smitty's's Avatar
Default Sniper DBW throttle body
Originally Posted by C5 Pete
OEM LS2 DBW throttle body.
What 92 mm throttle body do they use on a Sniper low profile intake. Will an LS2 work?
Old 02-09-2023, 10:01 AM
  #94
C5 Pete
AMP Racing
Support Corvetteforum!
C5 Pete's Avatar
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
The 90 (LS2) and 92 are interchangeable. Same bolt pattern. Same gasket.
Quick Reply: Intake Opinions
