3.25 pulley
Yes youll want at least an 8rib pulley setup. Use Vortech's calculator to check your impeller speed so youre not over-spinning it too much.
interesting topic. i just put a "3.15" pulley on the 1500 novi instead of the "3.48". first of all the diameter difference as measured on the outside of the belt is 7.7%. more remarkable is that i dont see much difference in boost in my loggs. even with some wishfull thinking thre is no more that 5 kpa. (0.7 psi). i have taken the engine only to 5500 so far (have been doing some tuning changes), but i would have expected to see around 20% more boost.
i dont have any slip, due to good belt wrap and a "hardcoated" pulley.
edit: diam. diff. is 7.7% as opposed to the theoretical 9.5%.
interesting topic. i just put a "3.15" pulley on the 1500 novi instead of the "3.48". first of all the diameter difference as measured on the outside of the belt is 8.5%. more remarkable is that i dont see much difference in boost in my loggs. even with some whishfull thinking thre is no more that 5 kpa. (0.7 psi). i have taken the engine only to 5500 so far (have been doing some tuning changes), but i would have expected to see around 20% more boost.
All that said - is there a chart available that shows pulleys and "expected" boost for superchargers?
His post says v2 🤔
3.25 doesn't require an 8 rib. That's a standard pulley for an ECS kit. I made 850rwhp with a 6 rib and a 3.125. Ty Wiseman made 925 on a Novi 2000 and 6 rib.
My car on a 6 rib. Made more on the bottle with the 6 rib.
Supporting Vendor
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
Probably because a bunch of them failed. I've had multiple friends have them fail. I only put 8,000 miles and weekend track passes on mine at 53,000 rpm, which isn't overspinning it in reality. Guys overspinning them big time.
