ABS module removal?
Old Jun 26, 2017 | 04:09 PM
Idahoctsv's Avatar
Idahoctsv
Default ABS module removal?
So I'm in the process of going turbo on my 99 c5 and My ABS module (I think that's what it's called) is taking up a list of potential room for making the turbo fit better. It has not been plugged in from the connector for the past 2ish years maybe and I have done highway pulls and brakes hard from 150mph with the braked never locking up on me before. It is a street car and I am looking to make more power.
Question is can I remove the whole module without affecting the braking or safety part of it? If so has anybody ever done it? Thanks.
Old Jun 27, 2017 | 09:18 PM
Cordes Performance Racing's Avatar
Supporting Vendor
mine's removed on my 03. cleans up a ton of room, you just have to do a proportioning valve for the brakes is all. I cut all the harness out and everything on mine. I do half mile and go 190 in the half with zero issues and drive mine on the street.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old Jun 28, 2017 | 07:30 AM
Turpid porpoise's Avatar
Turpid porpoise
Do you have a specific prop valve you would recommend? I am looking to do this over the winter and want to accumulate all the parts I can in the meantime.
Old Jun 28, 2017 | 02:14 PM
Idahoctsv's Avatar
Idahoctsv
Thanks very much! I'm certain I follow you on Instagram with your Blue c5 correct? Any chance you could list some of the parts you used to do yours as far as who you went with and all that?
Old Jun 28, 2017 | 03:32 PM
douniasg's Avatar
douniasg
I removed mine. I ran new lines to all the calipers and installed a wilwood adjustable porportional valve for the rear brakes.
Old Jun 28, 2017 | 04:04 PM
Supporting Vendor
wilwood unit, just a standard one, nothing special
see above, thank you for following us!!
yup this.
Old Jul 5, 2017 | 10:45 AM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Will cruise control still work after this is removed and codes turned off?
Old Jul 5, 2017 | 04:54 PM
douniasg's Avatar
douniasg
Don't know I am running the fast xfi. Op said his isn't plugged in. So in his case it wouldn't matter.
Old Jul 6, 2017 | 09:44 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
My car's not gangsta like some of you guys, but my ABS and power booster is gone. Just have lines to each brake caliper. No proportioning valve.
Track only car though.
Old Jul 6, 2017 | 10:06 AM
Turpid porpoise
This might work for me as well... Gotta make some room for this winters turbo relocation...
Old Jul 8, 2017 | 02:23 PM
all4spl's Avatar
all4spl
no tire lockup?
Old Jul 8, 2017 | 02:57 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
None.
No wheel speed sensors. No ABS. No way for anything to lock anything up.
Old Jul 8, 2017 | 03:14 PM
all4spl's Avatar
all4spl
Im saying from hard braking and locking up the brakes. No issues with that since there is no proportioning valve?
Old Jul 8, 2017 | 03:17 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Oh. Sorry bout that. Lol.
I have Strange drag brakes.
I don't brake hard enough to lock them up. I have gotten on them pretty aggressively while bracket racing, but so far haven't locked them up.
I'd really have to put my foot through the floor to get them to lock up.
Old Jul 13, 2017 | 07:56 PM
corvet786c's Avatar
corvet786c
Yea mine works, The dreaded service light abs/tcs will stay lit up. Mine is also disconnected from the module just hanging around up front. No problems though from braking. Also don't know who much volts are on the tcs system but better for lightweight batteries, less accessive battery draw.
Old Jul 13, 2017 | 08:41 PM
CamminC5's Avatar
CamminC5
To ABS module removal?
