procharger p1sc, can't find belt size
hey all, yes i did a search on forums and google but couldn't locate the correct belt size for a procharger p1sc with a stock crank pulley and a stock blower pulley using the updated ATI bracket assembly.....any help would be appreciated.
Received 1,261 Likes
that's what I have done in the past... when you get the size you think will work best it isn't a bad idea to get the next size up and down just to be on the safe side that way if it doesn't work you have the next available sizes in hand if you happen to need one of them so you can get the car running and take the other 2 back
