Supercharged - waterpump failure
Old Sep 18, 2017 | 05:59 AM
CorvetteC5Norway's Avatar
CorvetteC5Norway
Originally Posted by stevieturbo
But is it the correct length for the application ?
It sounds almost like it's very tight...ie potentially too short ?
yes, standard belt from ECS. Installed by proffesionals
Old Sep 18, 2017 | 11:47 AM
Smoken1's Avatar
Smoken1
I think it was from Jeg's
http://store.prw-usa.com/products/# ... 1434628
Old Sep 19, 2017 | 08:12 AM
romandian's Avatar
romandian
Originally Posted by CorvetteC5Norway
Well hurrahh! My new OEM pump broke the same way after 300 miles!
My installer is sure he is not overtightening the belt. What is happening? Smoken1; the pump in your picture, is that an upgrade from OEM? Where can I get it?
One thing I noticed by the road when I was removing the belt completely; it was really hard to get the belt removed from the balancer because the ECS spring tensioner was so close to the balancer. I was not able, with my hands, to move the spring tensioner at all. Is that right?
if the belt is without tension the pulley almost touches the balancer. thats how it is. there is a square hole below the pulley for a ratchet you move the tensioner with. how far up was the manual tensioner? what distance between the belt?
imo, dont trust the professionals, take everything apart, think about how it works and if it makes sence how it is. there might be some stupid mistake in the installation, like there was in mine, making the car eat pumps in your case.
Old Sep 19, 2017 | 05:55 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
If you want to look at aftermarket pumps, I prefer the Edelbrock over the PRW all day long. I believe it's part # 8896 and 8898 is the pulley. They're pricey, but I believe they flow a lot better up top.
Old Sep 20, 2017 | 09:41 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
As I said in your email, we use the Miezere mechanical. Regardless of what pump you choose, make sure the mounting tabs where the stock tensioner would have mounted (now the supercharger brackets) is the same as stock. I have seen people have belt issues from not checking that.
Old Sep 20, 2017 | 09:55 AM
CorvetteC5Norway
I saw this in another post, and has forwarded this info to Hans for verification. Right now Hans is looking into installing a new aluminum pulley on the oem water pump, since ESS has equipment for, and does design and manufacture pulley systems.
Old Sep 20, 2017 | 12:27 PM
romandian's Avatar
romandian
do you have picts of how the pump broke?
Old Sep 21, 2017 | 01:41 AM
CorvetteC5Norway
No, but it's pretty much the same as the one before and others I've seen here on the forum. It breaks in a ring around the axle a few mm into the "pulley" itself. Even I can see the reason for it breaking, there is between 5 and 10 cm sideways between the place where the pulley sits on the axle and where the belt runs on the pulley. There will of course be a great force pressing on the point of connection. And it's cast...
Old Sep 21, 2017 | 02:23 AM
romandian's Avatar
romandian
i also would say its cast and therefore question the wisdom of welding it to the shaft. be shure to post the aluminum pulley.
Old Sep 21, 2017 | 06:33 AM
stevieturbo's Avatar
stevieturbo
Are OEM pumps not pressed steel pulleys ?
I know my LS2 type definitely is, and pretty sure even my older LS1 type was
Old Sep 21, 2017 | 04:17 PM
algZO6's Avatar
algZO6
ive gone through two Miezere electrics and one eldebrock....both were junk. back to a stock unit with at tacked hub and all is well.
Old Sep 22, 2017 | 01:31 AM
CorvetteC5Norway
Tacked hub, could you plaese explain?
Old Sep 22, 2017 | 12:53 PM
  #33
algZO6's Avatar
algZO6
you tack weld the hub on the shaft to prevent it from walking.
Old Sep 22, 2017 | 01:32 PM
  #34
CorvetteC5Norway
Well, it's not walking its breaking clear off in the cast, so I cant see that working on this pump.
Old Oct 13, 2017 | 05:22 PM
  #35
CorvetteC5Norway
Here's the new aluminium pulley on the left, ready to be installed on the new oem waterpump 👍
Old Oct 17, 2017 | 10:40 AM
  #36
romandian's Avatar
romandian
what kind of picture is this? i cant see/open it. there is just a green box.
if i open it in a new tab, it sais unvalid protocol.
Old Oct 17, 2017 | 11:54 AM
  #37
Turpid porpoise's Avatar
Turpid porpoise
Pic is working for me.
To Supercharged - waterpump failure
Old Oct 17, 2017 | 01:09 PM
  #38
romandian's Avatar
romandian
thats fine. what do i do?
Old Oct 17, 2017 | 02:16 PM
  #39
stevieturbo
Pics work fine here.
I'll save it and upload it to the forum to see if that works for you ?
Old Oct 18, 2017 | 01:23 AM
  #40
romandian's Avatar
romandian
thanks, today i can see both pictures, for some reason. still wondering what kind of picture it is (hosted?), because i had the "little green box phenomena" befor.
as to the pulley: unbelievable. how much was it? from solid, i suppose. are you going to shrink it on the shaft?
