102MM Boost Issues
Old Aug 30, 2017 | 05:12 AM
Rkreigh's Avatar
Rkreigh
why not go back to a cable? I think the 102 indeed isn't needed but I'm curious how much hassle it would be to just run an old school manual 102
I have one of the sniper style intakes that has one and I'm curious to try it out!
Old Aug 30, 2017 | 10:19 AM
helga203's Avatar
helga203
Would it be possible to delete the functions that the computer controls??
Old Aug 30, 2017 | 10:26 AM
Pekka_Perkeles's Avatar
Pekka_Perkeles
Leave the old one into glovebox with long wires... :-)
Or change to a cable PCM (or flash cable tune in it, if it works that way).
Old Aug 30, 2017 | 03:16 PM
ysb02's Avatar
ysb02
Cable is fine but you lose the ability for the ecu to change the throttle position for traction or stability control. Might be a big con to some.
Old Aug 30, 2017 | 07:25 PM
helga203's Avatar
helga203
Can it be done to c5 1999??
Old Aug 30, 2017 | 08:45 PM
Rkreigh's Avatar
Rkreigh
with really high hp the factory traction control is more harm than good IIMHO
I'll stick with my foot and a nice direct connection that I'm in control of
I do agree though that the drive by wire with a really GOOD traction control would be the way to go.
I'm disappointed that the 102 stepper motor can't keep up.
Old Aug 31, 2017 | 06:49 AM
Pekka_Perkeles
Very easy with -99.
With 97...98 you need rewiring.
Old Aug 31, 2017 | 06:54 AM
Pekka_Perkeles
I think newer C5's have better traction control and/or active handling, but I've never used it with higher hp than stock, nor tried to tune it.
Old Aug 31, 2017 | 09:12 AM
ysb02's Avatar
ysb02
Probably but you'll lose the BCM.
Old Aug 31, 2017 | 01:12 PM
helga203's Avatar
helga203
Does anyone know where there is instructions??
Old Sep 9, 2017 | 03:14 PM
nutbuster's Avatar
nutbuster
Default NW throttle body
Don't even bother with the Nick Williams boosted throttle body! I went thru the same thing with mine. I have an LSX 427 with an F1X and tried the Nick Williams boosted throttle body and it did NOT help. I had to go with the stock LS 3 throttle body. That finally fixed my Reduced engine power issue. I wasted 750.00$ on Nick Williams the throttle body.
Old Sep 10, 2017 | 09:09 AM
helga203's Avatar
helga203
What boost are you at??
Old Sep 10, 2017 | 11:52 AM
  #33
nutbuster's Avatar
nutbuster
I was at !4 PSI boost
Old Sep 11, 2017 | 10:50 AM
  #34
algZO6's Avatar
algZO6
I wonder if it has something to do with the C5 PCM. My buddy has a standard NW on his C6 Z06 and has been flawless with his F1X setup.
Old Sep 11, 2017 | 05:04 PM
  #35
stevieturbo's Avatar
stevieturbo
Originally Posted by C5Natie
In my case its closing from 99% to 62% open. You can see it real time log on the lap top. This post is specifically about Nick Williams throttle bodies.
As a cause of REP, or from a controlling action from REP ?
As for needing 102mm...
As an example, this car runs high 6's at 200+ with a stock 90mm TB ( painted black, if that matters )
Old Sep 12, 2017 | 05:42 PM
  #36
C5Natie's Avatar
C5Natie
https://www.youtube.com/watch?v=OllhPaOWnIU
The forced air (boost) is physically forcing closed the tb blade with in turn causes REP by setting a fault code.
Never debated about what size tb is "needed" to achieve a particular power level. The NW 102mm is a popular part used by many so I'm simply sharing info.
Old Sep 12, 2017 | 05:49 PM
  #37
C5Natie's Avatar
C5Natie
I will say that the guys at Brian Tooley Racing told me this morning that the people using the new "boosted" NW tb or that have switched to it seem to be having success with it so far.
Like I said, I have a stock ported LS2 90mm in the shop but since I already had a 102mm from before and I'm doing this switch on a trade, I want to see if the new one will work. Also doing it to share any info I find along the way.
To 102MM Boost Issues
Old Sep 13, 2017 | 10:56 AM
  #38
Pekka_Perkeles
Thank you already.
This is what this forum is all about. Or should be.
Old Sep 13, 2017 | 03:25 PM
  #39
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
Here is my experience with this issue and an LS2 throttle body. The only thing that solved it for me was flipping it to where the blade moved in the same direction as the stock LS1 throttle body. I apologize for the missing pictures but I haven't had the time to fix the photobucket debacle.
https://www.corvetteforum.com/forums...-corvette.html
Old Sep 13, 2017 | 05:38 PM
  #40
C5Natie's Avatar
C5Natie
Good info, thanks. This is something I may look into. See which way the NW tb opens and maybe flip it around to test.
